Painting Valve Cover
Old Sep 28, 2007 | 06:45 AM
guardian_ang3l's Avatar
Default Painting Valve Cover
I have a valve cover that I want to repaint, the black powder coating (or whatever it is) is flaking in places. What's the easiest (or best) way to strip the stock paint job off so I can repaint it?
Old Sep 28, 2007 | 06:48 AM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
Default Re: Painting Valve Cover (guardian_ang3l)
Available at Autozone, Walmart. etc.
Old Sep 30, 2007 | 12:52 PM
burke420's Avatar
thats OR wire brush, sander, etc
Old Oct 11, 2007 | 01:57 AM
travis-b16a2-eg's Avatar
Default Re: Painting Valve Cover (-NA-aLL-thE-wAy-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -NA-aLL-thE-wAy- &raquo;</TD></TR><TR><TD CLASS="quote">Available at Autozone, Walmart. etc.
that **** works wonders...
Old Oct 11, 2007 | 07:41 AM
Unique Artwerkz's Avatar
Default Re: Painting Valve Cover (travis-b16a2-eg)
Also comes in a spray can Make sure you wear some nice thick gloves too!
Old Oct 11, 2007 | 08:24 AM
UrVtecIsLoud's Avatar
Default Re: Painting Valve Cover (Unique Artwerkz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unique Artwerkz &raquo;</TD></TR><TR><TD CLASS="quote">Also comes in a spray can Make sure you wear some nice thick gloves too!</TD></TR></TABLE>
I think the spray can sucks but if you get the container it works better I used that and a tooth brush to it works real good in corners
Old Oct 11, 2007 | 10:11 AM
Top Ramen's Avatar
Default Re: Painting Valve Cover (UrVtecIsLoud)
get the can of paint remover (not the spray). brush it on and let it sit for a while (20-30 min) then hit it with a power washer. may have to do it a couple of times.
best of luck with your project.
Old Oct 11, 2007 | 07:59 PM
vsmhatched's Avatar
aircraft stripper FTW
Old Oct 15, 2007 | 09:33 AM
Kirk GS-R's Avatar
deff the aircraft remover,works fine
Old Oct 15, 2007 | 12:51 PM
urbansi's Avatar
Default Re: (Kirk GS-R)
yea i havent used the air craft remover but i used some generic brand from autozone that wroked pretty well. Just make sure you let it sit for a little while before you try to remove, and oh yeah wear gloves, it doesnt burn at first but then it hurts like hell and makes your skin peal kinda
khurrum
Paint and Body
Jan 9, 2008 10:07 AM
R.and.Y
Paint and Body
34
Jun 14, 2007 07:25 PM
FhCRubarb
Jan 10, 2007 02:43 PM
stemiched
Jun 25, 2006 01:38 PM
DFW
Aug 29, 2005 11:16 PM
