Lsvtec build...
Old Sep 28, 2007 | 06:43 AM
JDMkidGSR's Avatar
Default Lsvtec build...
I have a few qustions I had a lsvtec built already. Stock block, stock gsr head.
My question was can I use a gsr headgasket and only use one layer of the headgasket. Im reading all types of threads saying about the valve to piston clearence but then I see that its got a 9:7 cp ratio. I just wanted to bump up the compression on it. So do I use the HG complete or will it be ok to use one layer.
Heres my lsvtec setup. (this engine is just temp till I get my gsr built)
ITR cams
skunk2 cam gears
skunk2 intake manifold
itr aem intake
apexi wsII catback
kenji p28
apexi vafc
ported throttle body.
Old Sep 29, 2007 | 03:31 PM
ls-vtec-delsol's Avatar
you have to use a ls head gasket, and with stock ls piston, you don't have to worry about valve-piston clearance. And your compression won't be high, since your block is still stock.
ivan93egreppin210
22
May 6, 2011 05:08 PM
hatchguy
Oct 26, 2004 08:48 PM
88civicHB703
30
Jul 24, 2003 05:33 PM
StinkyTofu
Jan 15, 2002 06:38 AM
