itb's rsx?
Old Sep 28, 2007 | 12:09 AM
nahonda04's Avatar
Surje.motorsports
Default itb's rsx?
i was looking into getting itb's for my rsx. i want to know if i need to change the cams with it or not. i understand the other stuff that going with it, i.e. fuel lines and pressure regs and vacuum lines, etc... can i run an intercooler on the car to get the temp in a good range without a turbo?
Old Sep 28, 2007 | 12:30 AM
doood's Avatar
been there done that
Default Re: itb's rsx? (nahonda04)
oh lord
1. what other mods do you have?
2. what makes you feel itb's are a good mod for you?
3. do you know how an intercooler works?
Old Sep 28, 2007 | 01:30 AM
nahonda04's Avatar
Surje.motorsports
dont know how an intercoller works exactly, just know it cools the motor. i have i/e/h img/rbc and k-pro, i want all n/a car with about 250-265whp.
Old Sep 28, 2007 | 01:42 AM
gsrob's Avatar
Default Re: (nahonda04)
Check out the forced induction forum for the way turbos and intercoolers work. And no, if you are naturally aspirated you won't be using an intercooler.
Old Sep 28, 2007 | 01:47 AM
nahonda04's Avatar
Surje.motorsports
how can i get my car cool enough to run a stable itb all motor setup? just the reg stuff to do it?
Old Sep 28, 2007 | 04:53 AM
b19coupe's Avatar
Get an 06 Civic SI intake manifold (RBC). IPS K2's and valve train. SSR, RCrew or SMSP header and full 3" exhaust. Tune. The car will be fast and a pleasure to drive.
Or get ITB's and spend lots of time tuning the car. Diveability will be hit or miss, depending on your tuner.
Old Sep 28, 2007 | 07:29 AM
b20sedan's Avatar
B20 Bhai M.B.B.S
Default Re: itb's rsx? (b19coupe)
Don’t listen to that noob ^^ ...an intercooler and itb’s will make for a sick dd. Make sure you get an intercooler sprayer too for those 100+ degree days.
Edit: better idea!
Run teh DC race header with the inlet of the intercooler piping at the end of the collector and have the intercooler piping on the other end empty over the itb’s…uninterrupted self sufficient air supply FTW…
Modified by b20sedan at 8:48 AM 9/28/2007
Modified by b20sedan at 8:52 AM 9/28/2007
Old Sep 28, 2007 | 08:23 AM
cartune network's Avatar
Default Re: itb's rsx? (b20sedan)
^^^^ thats messed up.
throw the intercooler idea out of the window.
get a good intake manifold and throttlebody.
a good set of cams and valvesprings go a long way on a k20 motor.
Old Sep 28, 2007 | 05:28 PM
b20sedan's Avatar
B20 Bhai M.B.B.S
Default Re: itb's rsx? (cartune network)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cartune network &raquo;</TD></TR><TR><TD CLASS="quote">^^^^ thats messed up.
What?
It's like kevin costner from waterworld (...FTL)
Old Sep 28, 2007 | 10:09 PM
yaaj1320's Avatar
my friend just dyno'd his k20 type-r
222whp--bolt ons...
206whp bolt ons and ITB's....
took forever to tune and came out with less power...spent about 7 hrs on the tuning...$900 and they gave us a discount...
i heard....when people do a "street car" with the itb's with the k20 like 6month later they usally go turbo...
Old Sep 29, 2007 | 09:35 AM
nahonda04's Avatar
Surje.motorsports
cant use intercooler on na cars, want all na, i already have the above listed stuff, need to know if i should change valves, valve springs, cars, cam gears and all that othe fun **** to go with the itbs, how do itbs usually add to the cars performance and whp?
Old Sep 29, 2007 | 11:25 AM
they flow alot more air than ur stock intake manifold and most modifed manifolds. if your going itb's then get cams, springs, retainers, cam gears and a good tuning program.
Old Sep 29, 2007 | 11:29 AM
9bells's Avatar
OG Fabricator
Default Re: itb's rsx? (yaaj1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yaaj1320 &raquo;</TD></TR><TR><TD CLASS="quote">my friend just dyno'd his k20 type-r
222whp--bolt ons...
i heard....when people do a "street car" with the itb's with the k20 like 6month later they usally go turbo...</TD></TR></TABLE>
It's the tuner, not the ITB's.
Some guys have seen big gains with ITB's on basically stock rsx.
They are hard to tune, most guys don't know the intricate details with alpha-n tuning.
Only Hayward and Hytech have ITB's that fit the rsx. Tons of midrange power and throttle response, small gains up top because of the runner length used to get around the power steering.
No intercooler on N/A cars, check out Clubrsx. com and k20a. org
Old Oct 2, 2007 | 06:17 PM
nahonda04's Avatar
Surje.motorsports
so for an all na car wud itbs contribute a nice amount of power to be suffice for my build numbers?
Old Oct 3, 2007 | 01:42 AM
Jdmsoles's Avatar
From: Dodgin Cops all Round Ana-Crime to Orange & Sd
so heres what im thinking what makes you think that you need a intercooler to cool down your motor when you have a aluminum block and head thats just stupid and also why would your temp go krazy with itbs its not turbo remember its not forcaed induction its naturally aspirated.......why do you want to run itbs and dont even know how the whole system is going to work or how to set up, and second your talking about cams valves retainers etc.. but you dont even know about itbs so why would you want to mess with internal stuff like cams and or lift duration .. and 9bells is right its not itbs that made that k20r slower it was just the tuner not trying to be a dick but damn ya know do research on your ish ya know ! GL either way
Old Oct 3, 2007 | 05:06 PM
nahonda04's Avatar
Surje.motorsports
honda-tech is research!
jdmjin
Jun 1, 2008 12:34 PM
Boilermaker1
Welding / Fabrication
Nov 5, 2006 11:00 AM
Boosted_K20
20
Jan 21, 2005 08:23 PM
n_23_s
Nov 11, 2004 02:46 AM
