Just picked up my APEX coilovers
Old Jun 18, 2002 | 01:31 PM
itchy's Avatar
Default Just picked up my APEX coilovers
I'll let you know what I think of them once I get them on. Thanks to all for the opinions last week. to all.
Old Jun 18, 2002 | 02:41 PM
4doorH22's Avatar
Default Re: Just picked up my APEX coilovers (itchy)
Gonna install them yourself?
Old Jun 18, 2002 | 03:21 PM
itchy's Avatar
Default Re: Just picked up my APEX coilovers (4doorH22)
I plan on it, probably this weekend.
Old Jun 18, 2002 | 07:30 PM
RJonathan's Avatar
Have fun install them man. I wish you good luck...
Old Jun 24, 2002 | 09:25 AM
95GSRRacer's Avatar
I have the 99 spec... Love them... Good luck and let us know.
Old Jun 24, 2002 | 09:48 AM
itchy's Avatar
Default Re: Just picked up my APEX coilovers (itchy) Installed!
Put them on over the weekend. Install was no problem. Car drives great, very happy with them. Highly recommend.
[Modified by itchy, 10:50 AM 6/24/2002]
Old Jun 24, 2002 | 10:16 AM
John's Avatar
New User
Default Re: Just picked up my APEX coilovers (itchy) Installed! (itchy)
Did you ever find out the spring rates?
Old Jun 24, 2002 | 10:18 AM
itchy's Avatar
Default Re: Just picked up my APEX coilovers (DunReit)
No I never did find that out. I checked their website, not to infomative.
Old Jun 24, 2002 | 10:25 AM
Nick H's Avatar
New User
post some pics man...how low did it drop your car?
Old Jun 24, 2002 | 10:36 AM
itchy's Avatar
Default Re: Just picked up my APEX coilovers (nickh2k1)
I will try to borrow a digital cam from someone and post up the pics. I adjusted the drop so I eliminated the wheel well gap altogether. I set the front end just slightly lower than the rear. Car still drives smooth as Hell.
I'm almost afraid to post pictures because I now I am going to get a ton of **** for having 18's on my car. Oh well.
Old Jun 26, 2002 | 07:59 AM
95GSRRacer's Avatar
The spring rates on the 2000 spec or type pro are 11Kg in front and 6Kg in the rear. This approx. equals 614lbs/sq in front and 335lbs/sq in rear. 13 way adjustable shocks adjusting both compression and rebound.
By the way, these are the static rates, (or uncompressed).
[Modified by 95GSRRacer, 11:00 AM 6/26/2002]
Old Jun 26, 2002 | 08:01 AM
Razor's Avatar
Default Re: Just picked up my APEX coilovers (95GSRRacer)
is APEX and APEx'i the same company?
Old Jun 26, 2002 | 08:06 AM
4doorH22's Avatar
Default Re: Just picked up my APEX coilovers (Razor)
Yes, same company. It's APEX Integration or APEXi for short.
Old Jun 26, 2002 | 08:08 AM
John's Avatar
New User
600+lb/in for the fronts? Holy p00p, that's a lot of understeer.
Old Jun 26, 2002 | 08:27 AM
itchy's Avatar
According to APEXi, these figures are way off. Spring rate is nowhere near 600. They are around 20-22% firmer than stock rates. They are going to email me the exact rate later today. I will post the actual numbers when I get them from APEXi.
Old Jun 26, 2002 | 09:57 AM
95GSRRacer's Avatar
This is the information that I got from two of their techs... I have been wondering about the rates... Thats why I called them. Then they tell me 11K in the front and 5K for the rear for the Type R coilovers (99 spec).
I am curious to see what they have to say.
Old Jun 26, 2002 | 10:00 AM
John's Avatar
New User
That's still an awful disparity between the fronts and rears for a ITR. Way too much understeer.
Don't forget that the WS coilovers for the Accord likely have different specs than the WS coilovers for the ITR.
Old Jun 26, 2002 | 01:29 PM
greensleeper's Avatar
the accord weight distribution is like 64/36. spring rates like that would be like... uhhh... like possibly the shittiest driving experience ever.
Old Jun 28, 2002 | 06:35 AM
95GSRRacer's Avatar
Sorry guys, I dont have an Accord(used to), and I dont have the WS Coilovers. I have the N1 dampers. The info I posted eariler was for the Type R N1 dampers. I would still like to know if the numbers I posted are correct. They do sound like a weird setup. Thanks.
Old Jun 28, 2002 | 08:15 AM
itchy's Avatar
Here are the numbers that I got from APEXi:
Front is 10k (558.8 lb.)
Rear is 4k (223.52 lb.)
Remember this is for an Accord V6, not an ITR. They drive fine. Handling is pretty nuetral, have not experienced any understeer.
ammob16
Nov 11, 2005 11:25 AM
TheThiefTheKnife'NTheGun
Suspension & Brakes
10
Sep 7, 2005 11:57 AM
jdmspoonitr
Jun 18, 2005 10:46 AM
kay_animation
Mar 15, 2003 07:45 AM
Anderson
May 21, 2002 11:22 AM
