Help with starting my car
Old Sep 27, 2007 | 05:58 PM
niterida's Avatar
Default Help with starting my car
Here's the situation.
lately when I turn the key, the car usually has a 5-10 second pause before the the starter kicks in and starts the motor.
It is completely temperature dependent.
Today is was kinda cold, and the car will not start now. The code reads #8, which is TDC sensor, which doesn't seem like it would have anything to do with the starter not engaging.
Does anyone think it could just be the starter? starter solenoid?
any help would be apprieciated
Old Sep 27, 2007 | 06:05 PM
niterida's Avatar
Default Re: Help with starting my car (niterida)
picture so people will open the thread
Help me I'm stuck
Old Sep 27, 2007 | 06:08 PM
Ultraspeed DC2's Avatar
sounds like a relay
Old Sep 27, 2007 | 06:12 PM
Sturmmann's Avatar
Check distributor, cap, rotor, ignitor (icm), and coil.
I had this problem constantly when turboed...distributor always wore out quickly...cap and rotor that is...using MSD setup.
Now Ultra MDI 9680 no problem at all...not using cap and rotors but direct ignition system.
The TDC/CKP/CKF sensor is in the distributor.
Old Sep 27, 2007 | 06:21 PM
niterida's Avatar
Default Re: Help with starting my car (Sturmmann)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sturmmann &raquo;</TD></TR><TR><TD CLASS="quote">Check distributor, cap, rotor, ignitor (icm), and coil.
The TDC/CKP/CKF sensor is in the distributor.</TD></TR></TABLE>
The car didn't pass Smog a few weeks ago and I replaced the: cap, rotor, coil, plugs, wires. It was doing this back then, but these didn't help/change the problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ultraspeed DC2 &raquo;</TD></TR><TR><TD CLASS="quote">sounds like a relay</TD></TR></TABLE>
which relay? ignition?
Old Sep 28, 2007 | 05:56 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by niterida &raquo;</TD></TR><TR><TD CLASS="quote">
which relay? ignition?</TD></TR></TABLE>
woops, test the ignition switch, this happend to my old DA9. Run a wire directly from the start to positive terminal, if that works good every time, then your ignition switch is bad, instead of fixing it i just made a pushbutton start setup
Old Sep 28, 2007 | 07:21 PM
niterida's Avatar
Default Re: Help with starting my car (Ultraspeed DC2)
woops, test the ignition switch, this happend to my old DA9. Run a wire directly from the start to positive terminal, if that works good every time, then your ignition switch is bad, instead of fixing it i just made a pushbutton start setup</TD></TR></TABLE>
I will try that tomorrow.
any more suggestions?
Old Sep 29, 2007 | 03:37 PM
COLIMA0003ITR's Avatar
take it do the shop
Old Sep 29, 2007 | 04:23 PM
niterida's Avatar
Default Re: (COLIMA0003ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by COLIMA0003ITR &raquo;</TD></TR><TR><TD CLASS="quote">take it do the shop </TD></TR></TABLE>
umm why?
I am a little more educated in cars than to just drop my car off at a shop and waste my money.
and learn how to type engrish
1990IntegraLS
Jun 2, 2019 11:17 AM
Yvettecands
Jan 7, 2014 09:50 AM
IEATLINT
Jun 9, 2004 10:30 AM
bKzSmUrF
Jun 25, 2003 04:40 AM
92TEGsrSC
Jun 18, 2003 09:15 PM
