For those of you with a Progress rear sway...
Old Sep 27, 2007 | 03:17 PM
WhiteOnRice's Avatar
Default For those of you with a Progress rear sway...
I have an 02 Si. The part number I got was 26.0102 but the bar seems a little too long. The endlinks (I have corsport endlinks) seem like they have a lot of pressure on them. I also had to turn the endlink around (as opposed to stock) so I could get it to fit. Should I worry about my endlinks? What did you guys do about the exhaust touching the swaybar?
If anyone has pics of their bar install I would like to see it to compare.
Old Sep 27, 2007 | 04:26 PM
Aco512's Avatar
i sold my rear sway mainly because of the touching problem
do you have a rh? if so, what kind
Old Sep 27, 2007 | 04:58 PM
Yeah, DCRH. But I'm talking rear sway. How did your endlinks look when bolted up to the bar? They they would break?
Old Sep 27, 2007 | 05:58 PM
Aco512's Avatar
can't really answer that question because i used the stock endlinks for the short time that i had it
the reason why i ask the type of header you had is because that is the problem with the touching you have with the swaybar (dcrh)
when i sold it to my friend, he didn't have that problem
i asked him what was the difference between his setup and mine
he said he added an adapter(extention) between his raceheader and his midpipe
seems to take care of that problem
Old Sep 27, 2007 | 06:00 PM
Really? How long was the pipe?
Old Sep 27, 2007 | 06:21 PM
Aco512's Avatar
he didn't added much, i'm not sure the exact size
just looking at where the rear bumper and tip was, you can tell the difference
mine was more sunk in, where as his still looked stock
Old Sep 28, 2007 | 10:39 AM
Anyone else?
Old Sep 28, 2007 | 01:00 PM
JDMk20R's Avatar
should be the same for the dc5, I have the stock endlinks on my sway and they're screamin for mercy lol
Is it adjustable or just the bar itself?
Old Sep 29, 2007 | 08:53 AM
The endlinks are adjustable, the bar is not. I have the endlinks as short as they will go. Making them longer would just give them more stress. So the stock are holding up? Then I can trust my corsports.
I don't know how anyone can get stock endlinks off without a grinder... I cut 3 of 4 off.
Old Sep 29, 2007 | 12:52 PM
Todd00's Avatar
I said I don't want a title!
Default Re: For those of you with a Progress rear sway... (WhiteOnRice)
A little long how? You mean too far out towards the wheel or something?
FWIW, I'm running the Mugen 25mm rear bar with OEM endlinks. No problems whatsoever.
phat00civic
Suspension & Brakes
19
Jan 13, 2012 01:51 PM
mitcho
Sep 4, 2008 11:47 AM
anothaDC2
Suspension & Brakes
May 24, 2007 02:25 PM
tthomass
Suspension & Brakes
14
Apr 11, 2005 01:00 AM
