am i getting beat?
Old Sep 27, 2007 | 02:03 PM
deeweezy187's Avatar
Default am i getting beat?
i was told by a shop it was going to cost 409.10 to change my clutch master clyinder and passenger side wheel bearing is this correct?
Old Sep 27, 2007 | 02:22 PM
Trae's Avatar
What is correct?
The wheel bearing alone is probably $80 plus the labor to install it, is probably another $120. That's $200 for the wheel bearing alone, rough estimate.
the MC is probably another $1XX plus an hour or two's worth time to put it in...
Old Sep 28, 2007 | 05:10 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: am i getting beat? (deeweezy187)
if you have some time and basic tools you can replace the clutch master cylinder yourself. I'm actually helping a friend replace one on his 93 Civic later today.
The wheel bearing would be a bit more difficult since you need a press to remove the inner race and press the new bearing and hub together. Of course you could remove the parts, take them to a machine shop and pay 25 or so to have the press work done.
If you want to save some money try doing it yourself, the clutch master cylinder shouldn't be that hard. Otherwise, that price sounds ok I guess.
Old Sep 28, 2007 | 05:12 AM
rleonekc's Avatar
sounds about right, unless you wanna do it yourself
Old Sep 28, 2007 | 10:21 AM
tpot90's Avatar
Default Re: am i getting beat? (rleonekc)
If you are going to replace the MC, you really should replace the SC while you are at it. If not, the worn slave will quickly wear on the new master..and vice versa.
cmasino
Honda Civic (2001 - 2005)
Jul 25, 2017 01:13 PM
Bizzle5OH3
Transmission & Drivetrain
May 31, 2011 09:02 AM
hondaracin24
Jul 2, 2006 06:08 AM
Tuesdaynightfever
Apr 16, 2005 06:29 PM
Tony Starks
Jun 28, 2003 06:44 AM
