JRSC Injector help!!
Old Sep 27, 2007 | 12:54 PM
end005's Avatar
Default JRSC Injector help!!
delete
Modified by end005 at 6:52 PM 10/6/2007
Old Sep 27, 2007 | 01:07 PM
end005's Avatar
Default Re: JRSC Injector help!! (end005)
help??
Old Sep 27, 2007 | 01:24 PM
end005's Avatar
wow. this forum is expletive dead.
Old Sep 27, 2007 | 01:36 PM
EASY101's Avatar
* B A N N E D *
you probably just need the clips
Old Sep 27, 2007 | 01:42 PM
Spunkster's Avatar
You cannot simply swap the injectors. You will have to change the injector clips, tehn you will have to use something like the Hondata s300 wich uses an OBD1 ecu to fully tunie it on the dyno. If you try to use 440's on a stock ecu you will just run very rich, wash down teh bores and screw your rings and bores.
Old Sep 27, 2007 | 04:38 PM
i2un's Avatar
Default Re: JRSC Injector help!! (Spunkster)
For about $30 more than the regular 'RC clips' you could also buy a the 'RC plug & play clips'.
It comes in handy if you ever think you'll need to switch back and forth, or if you don't want to splice into your harness.
thanh4o8
May 29, 2009 01:17 PM
Charlie Moua
May 15, 2009 10:31 PM
fortynineR
Aug 30, 2007 03:08 PM
Boilermaker1
Mar 18, 2007 08:29 PM
VTC_CiViC
Oct 30, 2001 11:59 AM
