4th gen rad support
Old Sep 27, 2007 | 11:16 AM
jon.e's Avatar
Default 4th gen rad support
Now im looking to put on a new rad support after my fender bender.
When i was looking at it yesterday, it looks like it is spot welded on.
im curious what do i have to do to get it out?
just drill out the holes and take off some bolts?
if thats the case than its easy.. but how would i put the new one on, if i have no spot weld?
just drill a hole and stick a bolt in?
thanks for anyones help
-jon
Old Sep 27, 2007 | 04:09 PM
jon.e's Avatar
Default Re: 4th gen rad support (jon.e)
anyone?
Old Sep 27, 2007 | 08:12 PM
Ludster's Avatar
The whole rad support is spot welded in and it is best to use the specific spot weld drill bit to remove each weld. You will then need to line up the new support and reweld it to the chassis(usually the same spots where the previous welds were)
Old Sep 28, 2007 | 05:04 AM
prelude_h22vtec's Avatar
yeah the spot weld bit works best so you dont mess up the metal behind it. but if your lazy, a normal drill bit and a hammer and a chisel will get it off.
Old Sep 28, 2007 | 06:49 AM
jon.e's Avatar
Default Re: (prelude_h22vtec)
alrite thanks for your help.
but still curious..
if i dont have a welder, or spot weld. how would i get it to stay on?
im assuming i could just rent a spot weld from a place?
or do i drill holes and leave a couple bolts in?
i wanna know the lazy way and the proper way.
thanks again
-Jon
Old Sep 28, 2007 | 02:02 PM
JDMLude850's Avatar
i rear-ended someone about 2 years ago, and the lude was down for about 4 months, bought a radiator support from rockauto.com i think?? drilled out the welds and used a air chisel to get it off. then my uncle spot welded it back on. then threw on my new headlights, carbon fiber hood, and fender...painted the lude in my backyard. saved a few thousand.
95accord-R
May 14, 2013 08:39 AM
m1ndless
Jan 16, 2008 01:34 PM
turbotime
Oct 17, 2006 04:37 PM
kraven9
13
Sep 14, 2006 03:41 AM
Race Egr
Welding / Fabrication
27
Apr 20, 2005 01:05 AM
