serial number on the motor??
Old Sep 27, 2007 | 10:49 AM
GSR_hatch936's Avatar
Default serial number on the motor??
where is this found on a gsr need to know car faxs on it!!
Old Sep 27, 2007 | 11:16 AM
Default Re: serial number on the motor?? (GSR_hatch936)
help anyone!!!!????
Old Sep 27, 2007 | 11:54 AM
LaosGuySi's Avatar
sifu pai mei
if the vin# is not on it, then its probably stolen.
Old Sep 27, 2007 | 11:56 AM
cartune network's Avatar
Default Re: serial number on the motor?? (LaosGuySi)
car fax also doesnt store serial numbers unless the previous owner put them in themselves. if u have no vin u most likely have a stolen motor. the only way to run a serial number is if u bring the motor to the police department and then when it comes up stolen or not at all they take the motor from you.
where is this that found?? thats wat im askin??!~!!
Old Sep 27, 2007 | 12:00 PM
wheres what found? the serial number? the serial number should be right underneath the engine code stamped on the block.
Old Sep 27, 2007 | 12:11 PM
Default Re: serial number on the motor?? (cartune network)
imma take a pic of my engine code and tell me where it is!
Old Sep 27, 2007 | 12:15 PM
LaosGuySi's Avatar
sifu pai mei
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cartune network &raquo;</TD></TR><TR><TD CLASS="quote"> the serial number should be right underneath the engine code stamped on the block.</TD></TR></TABLE>
i think its a green colored plate. that's what mine shows.
Old Sep 27, 2007 | 12:19 PM
??? is this it?? i know the engine code but not the s/n im not sure....??
Old Sep 27, 2007 | 12:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LaosGuySi &raquo;</TD></TR><TR><TD CLASS="quote">
i think its a green colored plate. that's what mine shows.</TD></TR></TABLE>
where is that located??? under the block behind left right???
Old Sep 27, 2007 | 12:22 PM
b19coupe's Avatar
The serial number of the engine block and the VIN are two separate numbers. The VIN plate is green and is just above the oil pan, near the dipstick tube.
Old Sep 27, 2007 | 12:25 PM
Default Re: serial number on the motor?? (b19coupe)
ok ty let me go check now!
Old Sep 27, 2007 | 02:06 PM
i thought u were talking about the serial number? serial number and a vin number are 2 different things man.
in the picture above it shows the engine code which is b18c1 and right under that number is ur serial number. the vin number is on a green plate that looks like every other vin plate.
Old Sep 27, 2007 | 04:43 PM
2ltrtodd's Avatar
* B A N N E D *
jdm motors dont have vins on them.
Old Sep 27, 2007 | 05:55 PM
NJIN BUILDR's Avatar
Default Re: (2ltrtodd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ltrtodd &raquo;</TD></TR><TR><TD CLASS="quote">jdm motors dont have vins on them.</TD></TR></TABLE>
And pre 1996 ish engines don't have vin numbers either.The number below the engine code is not uniuqe to that engine.Many blocks will have the same numbers.
Old Sep 28, 2007 | 09:59 AM
Default Re: (NJIN BUILDR)
ok so is my engine obd1???? need to know going to take it out and put a sohc for right now and the sohc is a obd1 and if it is they just match up right?? but gonna rebuild the gsr!!!
CARMA_626
Dec 12, 2010 04:33 PM
CARMA_626
18
Apr 20, 2008 07:27 PM
JUN.
Jan 15, 2006 07:21 AM
shtalker
Oct 23, 2005 04:21 AM
sporkcrx
Feb 7, 2004 08:21 PM
