that honda rattle.........
Old Sep 27, 2007 | 10:44 AM
Notjusdrivin's Avatar
Default that honda rattle.........
i got all this exhaust work the past couple years and i have this disgusting rattle.i took off 9 feet of heat shield from my 97 accord....anyone got that problem or solved that problem? ideas? please they laugh they all laugh....
Old Sep 27, 2007 | 11:56 AM
accord99power's Avatar
Default Re: that honda rattle......... (Notjusdrivin)
where do you hear it most man? Front of engine? rear of car? middle of car? Inside the engine? if its under get under the car and find out. Basically your gonna help your self the most here.
Old Sep 27, 2007 | 01:28 PM
Hammer99ex's Avatar
Default Re: that honda rattle......... (accord99power)
i just fixed a nasty rattle, it was the exhaust hanger tapping against the center of the rear sub frame, annoying as hell. i used a propane torch to heat and then bent it away
if you need to do this, be very careful, the gas tank is only a few inches away...
Old Oct 10, 2007 | 10:10 AM
yea its in the front. i took off about 9 feet of heat shield already. i got the dc sports header magnaflow high cat dcsports cat back exhasut but it came with a pre cat so they took it off when i got the header and hi flow. then i also had to custom make a 4 inch pipe to connect the flex pipe to the high flow or some **** cuz the damn header wasn't made for cali cars and of course i find out thats exactly where my car came form. so now i got this rattle, a blown 02 sensor and i also have this stupid venom 400(POS) which claims it auto-adjusts fuel and air and all that bs. i don't know if anyone is familiar with the venom but the LED light is comming on when ';m not even on the accelorator. i hate it all. and really all this exhaust work is gonna go to waste cuz i wanna either get that euro R from the 97, or the k24a swap from hasport or w/e. and for the money with the swap its will be so much better than the set up i got now. but i dunno trouble trouble 10k for a 15.99 on the 1/4 with bad plugs and no oil, not too bad i guess. i dunno....i'm gonna go dream summor now thanks fellers
Old Oct 10, 2007 | 10:24 AM
oem_certified_accord's Avatar
i had a ticking time bomb rattle a while back..i threw my car up on the lift and there it was..no hanger grommet rubber housing fitting thing
Old Oct 10, 2007 | 10:45 AM
noobking's Avatar
Default Re: that honda rattle......... (oem_certified_accord)
I've got a rattle that happens when i shift and continue to accel. really annoying, but it seems to be happening right under the drivers seat. Anybody have a suggestion. not trying to jack the thread here!
Old Oct 10, 2007 | 03:47 PM
JimBlake's Avatar
Default Re: that honda rattle......... (noobking)
There's like a dozen places for it to rattle, so each of you need to get underneath & figure out where YOURS is rattling.
Old Oct 10, 2007 | 04:52 PM
noobking's Avatar
Default Re: that honda rattle......... (JimBlake)
Is it kind of obvious where it is rattling from? Is the heat shield usually rusted or can it be a combination of problems?
Old Oct 10, 2007 | 05:37 PM
sony224422's Avatar
does it rattle at 2000 rpms or all rpms?
If its only durning acceleration, then get down under your car and put some hose clamps on your cats heat shield.
Also, look back around your muffler, i had a hanger or something brake back there and tickle the frame, it was really annoying and took me awhile to find.
Old Oct 11, 2007 | 07:23 AM
CB7Pirate's Avatar
Check your header as well. When I had a header on my car, I had a super annoying rattle. It was so bad I finally just took the stupid thing off...
Old Oct 11, 2007 | 07:40 AM
sony224422's Avatar
Default Re: (CB7Pirate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CB7Pirate &raquo;</TD></TR><TR><TD CLASS="quote">Check your header as well. When I had a header on my car, I had a super annoying rattle. It was so bad I finally just took the stupid thing off...</TD></TR></TABLE>
so you don't have a header now?
or do you have no headshield over it.
Old Oct 11, 2007 | 11:52 AM
CB3 freak's Avatar
i got that same rattle problem with mine.. i have a 93 accord but it doesnt rattle if i drive slow it only does it if i floor it.. i think its my (pos) muffler.. im thinking about getting an apexi muffler hopefully that solves the problem.. any sugges??
jhuck
Apr 17, 2012 07:12 AM
jhuck
Apr 17, 2012 05:49 AM
IntegraLs94Cam
Oct 1, 2004 05:43 AM
oMek
Aug 18, 2003 07:11 AM
HatchBox
15
Jul 21, 2002 05:37 PM
