Question about primer color...
Old Sep 27, 2007 | 09:05 AM
Ep1dem1c's Avatar
Default Question about primer color...
Does it matter what color primer you use on a car? Like say if one car is primered black and one car is primered grey... after painting them will they be the same color or will the black primer make the color darker? thanks...
Old Sep 27, 2007 | 09:52 AM
powerflow's Avatar
Default Re: Question about primer color... (Ep1dem1c)
Yes is does matter. If the job is done right, full color coverage will be achieved and the color will be exactly the same as when it was chosen and mixed. Depending on how the job is sprayed, the painter should choose the closest available primer, tinted sealer or ground coat according to the base color. Some base colors/brands cover well some do not, wich should be determained before hand. Light with light undercoats, dark with dark undercoats, med with med gray undercoats.
Old Sep 29, 2007 | 08:44 PM
iam7head's Avatar
Default Re: Question about primer color... (powerflow)
ding ding ding
for example alot of econo line B/C will have less pigment in it(cough..omni) which require you lay more down or primer will should thru.
that's the only reason why they offer 5-6 color of primer(black, white, grey, red, etc)
Old Sep 29, 2007 | 09:01 PM
EK9Tune's Avatar
So if I were to paint my lip Y-52P(yellow) I should use a light primer?
Old Sep 29, 2007 | 10:24 PM
iam7head's Avatar
Default Re: (EK9Tune)
yes, go with a light shade.
make sure you get a good base coat, some econo line yellow pigment is a bi-ch to spray
Old Sep 29, 2007 | 10:41 PM
EK9Tune's Avatar
im planning to rattle can it, would you suggest rolling it? i can't really tell the difference.
what brand and type of primer should i buy?
Golden Eagle
Performance
Nov 21, 2010 08:10 AM
uses0ap
Paint and Body
Oct 31, 2009 02:30 PM
4gencivicef9
13
Nov 22, 2007 08:10 PM
aeboync
Mar 3, 2006 09:11 AM
NMZ
Dec 23, 2005 07:54 PM
