axle trouble
Old Sep 27, 2007 | 08:00 AM
-91Si-r-'s Avatar
Default axle trouble
i have 1991 crx si that i am doing a dohc zc swap and i am wandering what axles and ecu i need to use?
Old Sep 27, 2007 | 08:18 AM
wiZCo's Avatar
Stouts 'n' Scotch
What transmission are you using?
For ECU you can use your stock PM6, a PG7 out of an 88-89 Integra or a PM7, which is the stock DOHC ZC ECU.
Old Sep 27, 2007 | 08:20 AM
-91Si-r-'s Avatar
Default Re: (wiZCo)
more than likely i will be using the zc tranny
Old Sep 27, 2007 | 08:40 AM
dubzz24's Avatar
Default Re: (-91Si-r-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -91Si-r- &raquo;</TD></TR><TR><TD CLASS="quote">more than likely i will be using the zc tranny</TD></TR></TABLE>
If you're using a ZC transmission, you'll need to use the ZC intermediate shaft with 90-93 Integra axles. If you end up using the Si tranny, use Si axles.
Old Sep 28, 2007 | 03:02 PM
-91Si-r-'s Avatar
Default Re: (dubzz24)
awsome thanks for the help
loudes13
Jun 9, 2009 07:19 PM
Spazius
Jun 16, 2007 02:03 PM
Sherm
Jan 12, 2004 06:16 PM
VELOCITY R
Nov 8, 2003 06:32 AM
SIRX
Dec 23, 2002 02:47 PM
