prep work for h22
no response in hybrid forum.... I've been thinking about swapping an h22 into my 1995 civic 4 door i've heard new suspension is a good idea....ne suggestions or other stuff i may want to put on to make this a great swap...thanks
could go with a gsr brake swap, but i have heard stock calipers are ok, but bigger slotted rotors and better pads are ok, and upgraded shoes for the discs in the back...... buuuuuuuuuuuut im not sure
what kind of suspension and brake upgrades would u fellas suggest...remember my pockets are not that deep
up
ne more suggestions or places online where I should get this stuff from... if anyone knows what price range i am looking at to prepare for this that'd be nice...thanks
turbo b18b 10psi u can smoke anything! well close to it.
new suspension, 4 wheel disc big brakes, put H22 in a dumpster and buy a GSR motor with a B16 head.
the topic = prep work for h22, also hence he asked about swapping an h22 what other things he should do...didn't say anything about other motor suggestions.
as for upgrades, good rims/tires, strong axles (yes, strong) from driveshaftshop.com, good mounts, upgrade brakes, and put integra performance springs in there, and you'll be set.
hey, he hasn't made the mistake of putting an H22 in his car yet. if he is staying naturally aspirated, he should use a GSR bottom end with a B16 head. that is the route he should take, considering that that chassis was designed for a B series motor and he can use other stock honda parts for the swap, axles, shift linkage, ecu. all plug and play.
and how exactly is putting an h22 in a civic a mistake?
h22 is king in both n/a and fi fields in hard core racing, who wouldn't want the best.
yes b series motors are good as well
lagingtorpe
Apr 28, 2006 09:25 PM
Insperation
Aug 25, 2004 12:25 PM
