Will 92-95 shocks fit my 89 si?
Old Sep 27, 2007 | 01:38 AM
wakaranai's Avatar
Default Will 92-95 shocks fit my 89 si?
As the title says, I am trying to figure out if they are a direct bolt on or if modification is necessary to install these.
Old Sep 27, 2007 | 03:40 AM
Cory man's Avatar
Default Re: Will 92-95 shocks fit my 89 si? (wakaranai)
IIRC the only difference between the 2 is the shock fork hole(where the shock rests)is a bigger diameter for the 92-95 models. hth
Old Sep 27, 2007 | 09:28 AM
wakaranai's Avatar
Default Re: Will 92-95 shocks fit my 89 si? (Cory man)
I see. I guess my only option would be to switch forks then?
Old Sep 27, 2007 | 09:30 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cory man &raquo;</TD></TR><TR><TD CLASS="quote">IIRC the only difference between the 2 is the shock fork hole(where the shock rests)is a bigger diameter for the 92-95 models. hth</TD></TR></TABLE>
That and the EG shocks are taller.
Old Oct 14, 2007 | 10:57 AM
zenon8890's Avatar
how much taller? what about after market shocks and springs?! performance shocks?! cuz i have some tiens and i can find any crx shocks even stock ones, i'm using 19 yrs old shocks and ebay crap springs
Old Oct 14, 2007 | 12:46 PM
welfarepc's Avatar
ive been told by Omni power that the EG shocks are interchangeable with EF's you just need EG forks.
they didnt mention anything about height.. then again they were adjustable coils
hondapimp125
Suspension & Brakes
Mar 8, 2008 11:26 PM
Agent Daimon
Jan 3, 2007 06:22 PM
H.crx-si
Nov 23, 2004 05:14 PM
ImprtTuner88
Dec 6, 2003 10:25 AM
FrostyDC4
May 1, 2003 05:31 PM
