why obd0 better that obd1?
Old Sep 26, 2007 | 07:30 PM
zamrioo2's Avatar
Default why obd0 better that obd1?
hi guys,
i need some input here why many people change obd0 to obd1 wiring...? i found that obd1 has 64wire compare with obd0 only 54wire which means more simpler...
i need to know this because i'm using b16a with pr3 obd0 and plan to swap p30 obd1 if proven that p30 obd1 making more power...
thanks...
Old Sep 26, 2007 | 07:34 PM
doood's Avatar
been there done that
Default Re: why obd0 better that obd1? (zamrioo2)
there are more engine management choices for obd1
Old Sep 27, 2007 | 04:46 AM
mar778c's Avatar
Community Builder
Community Influencer
Just chip the pr3 and use BRE from the pgmfi.org.
Old Sep 27, 2007 | 07:07 PM
ls-vtec-delsol's Avatar
most of why everyone convert to obd 1 is for hondata. Its the most reliable piggy back for honda, and its cheap. You should think about it too. With pre obd, you can't tune car to spec.
Old Sep 27, 2007 | 07:42 PM
integrawow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">hi guys,
thanks... </TD></TR></TABLE>
No dude, you're missin' tha' point. I want you to try something. I want you to go to your local Honda dealer to the parts department and ask for a distributor, both o2 sensors, and ecu for a 91 Honda Integra DA6. At this point you should start understanding where i'm coming from.
If you have a golden opportunity to convert to OBD1, then I suggest you do it. This old OBD0 PR3 sh#t is hard to come by. You can't just go to a local parts store and get some of the hard parts like the distributor, ecu, and sh#t like that. However, you can go just about anywhere and get a distributor for a 94 Honda Del Sol B16A3.
Get my point. If I could, I would go the OBD1 route and purchase Hondata. Believe me here. Hondata is tha' way to go. There are alot of shops who carry Hondata, so you'll be well suited. The key thing that you should understand is that even if you don't make more power with the OBD1 stuff, you'll still have an easier time getting parts, and the effort it took to go OBD1 would then be well worth it.
I hope this helps.
Old Oct 1, 2007 | 10:13 PM
zamrioo2's Avatar
thanks guys...
i'll keep the obd0 because a set of obd1 with ecu is over the budget...
Old Oct 2, 2007 | 12:38 AM
zap's Avatar
zap
then Ben's ROM Editor is for you bro
iamalex1212
Apr 12, 2011 11:10 AM
