brake light switch problem
well, i heard its a popular thing to happen to hondas and now it happened to me.
the plastic on the brake light switch on the pedal broke. now my brake lights stay on and drain my battery. i heard somebody talking about using a bolt and nut for a permanent/more effective fix? how is this done? also heard the same method could be used for the clutch pedal for the neutral safety switch. anyways...HELP, HONDA-TECH!
Modified by EGchris at 7:59 PM 9/26/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marquisdee1018 »</TD></TR><TR><TD CLASS="quote">I used a bolt and 2 nuts to fix mine. The bolt goes through where the plastic part was and nuts one each side to keep it in place.</TD></TR></TABLE>
did the same thing, works better actually because you know it will never brake again since its not that cheap honda plastic
BlueIntegraBoy
May 26, 2021 10:40 AM
gsrsuperman
13
Jul 21, 2008 10:20 AM
