TB coolant bypassed? Insulated Gaskets? Under hood tempratures? Looking for 10 HP
Old Sep 26, 2007 | 03:22 PM
JunkyardDog's Avatar
Default TB coolant bypassed? Insulated Gaskets? Under hood tempratures? Looking for 10 HP
Looking to squeeze out the last few drops of power out. Contemplating bypassing the TB coolant line. Question will there be and drive ability problems if I do and has anyone done this and gotten positive results.
Intake manifold Insulated gaskets. I heard they leak after a wile, I don't know first hand. Is it worth the pain in the A** to pull off your Intake manifold and what kind of results have you guys gotten.
Now I see someone selling TB Insulated gaskets Anyone got feedback on these?
Old Sep 26, 2007 | 05:36 PM
Default Re: TB coolant bypassed? Insulated Gaskets? Under hood tempratures? Looking for 10 HP (JunkyardDog)
Should I go and ask the turbo guys?
Old Sep 26, 2007 | 05:38 PM
Combustion Contraption's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JunkyardDog &raquo;</TD></TR><TR><TD CLASS="quote">Should I go and ask the turbo guys? </TD></TR></TABLE>
yes.
Old Sep 26, 2007 | 06:53 PM
Ryank327's Avatar
You won't really see much of a gain if any with a TB bypass by itself. But combine it with a Insulated IM Gasket and theres a possibility you could gain 10 hp depending on your setup.
Old Sep 26, 2007 | 07:00 PM
all-mtr-teg's Avatar
Those tips will work for a while, but eventually the manifold and t.b. will absorb heat from the engine bay and your gains will be minimal. I have done both on my GSR but i really can't tell a difference on the BUTT DYNO.
Old Sep 26, 2007 | 07:13 PM
Default Re: TB coolant bypassed? Insulated Gaskets? Under hood tempratures? Looking for 10 HP (all-mtr-teg)
kinda how I feel about it and I'm thinking I'll get 2-3 hp for a hole lot of work that may make the car less reliable.
Old Sep 27, 2007 | 12:03 AM
LSVTEC 91 Civic's Avatar
Banned
Ghetto cowl induction = washers under hood latch.
Old Sep 27, 2007 | 12:29 AM
Chris Tune's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JunkyardDog &raquo;</TD></TR><TR><TD CLASS="quote">kinda how I feel about it and I'm thinking I'll get 2-3 hp for a hole lot of work that may make the car less reliable.</TD></TR></TABLE>
why would it be less reliable, are you that bad of a mechanic? theres no detrimental effects for any of those 2 mods you just posted, unless u are in alaska... meaning the north pole where u would need coolant running through your TB
Old Sep 27, 2007 | 11:52 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
Default Re: TB coolant bypassed? Insulated Gaskets? Under hood tempratures? Looking for 10 HP (Chris Tune)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris Tune &raquo;</TD></TR><TR><TD CLASS="quote">
why would it be less reliable, are you that bad of a mechanic? theres no detrimental effects for any of those 2 mods you just posted, unless u are in alaska... meaning the north pole where u would need coolant running through your TB</TD></TR></TABLE>
Will all of those who have no geographical knowledge and a hankerin to post an insult please stand up?
I'd do it, maybe try wrapping a couple things and keep the heat where it should be.
Old Sep 27, 2007 | 12:54 PM
ToeJam's Avatar
This is how i did mine.
Old Sep 27, 2007 | 08:30 PM
ChickenH's Avatar
I bypassed mine and got a hondata intake gasket. it was a lot cuter after IMO. But there wasn't a noticeable difference on the butt dyno. and im sure when it gets cold it will idle like poo on cold startup..
Old Sep 27, 2007 | 08:35 PM
Default Re: TB coolant bypassed? Insulated Gaskets? Under hood tempratures? Looking for 10 HP (ToeJam)
Thanks for the input guys I just put this out there because I didn't want to reinvent the wheel.
OK I have a new header on the way, I may wrap it before installing it. I also have a short ram pipe made out of aluminum, which I was planning to replace with a Type R Intake arm from Acura to cut down on heat.
1. Anyone know the inside Diameter of the Type R one? I can easily bypass the TB so I may try that but unless you guys have seen good numbers with the Intake manifold gaskets I'm probably not going to do that.
2.One more question for the tuner guys, Is it possible to get over 190 HP with stock GSR injectors and a HP fuel pump and a Crome engine management system?
Old Sep 27, 2007 | 10:15 PM
salman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">Those tips will work for a while, but eventually the manifold and t.b. will absorb heat from the engine bay and your gains will be minimal. I have done both on my GSR but i really can't tell a difference on the BUTT DYNO.</TD></TR></TABLE>
This really happen after 20 mins of driving,,,
Old Sep 28, 2007 | 07:17 AM
Default Re: TB coolant bypassed? Insulated Gaskets? Under hood tempratures? Looking for 10 HP (salman)
Yeah, you might see gains if the car is on the dyno and you got a cold engine bay, but once it gets hot, the manifold will absorb the heat and your gains will be minimal or non.
Old Sep 28, 2007 | 07:26 AM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, you might see gains if the car is on the dyno and you got a cold engine bay, but once it gets hot, the manifold will absorb the heat and your gains will be minimal or non.</TD></TR></TABLE>
I have datalogged the difference with/without the Hondata intake gasket on the street. The intake air temps were ~ 20 degrees cooler with the Hondata gasket.
Old Sep 28, 2007 | 09:11 AM
an2ny888's Avatar
Default Re: TB coolant bypassed? Insulated Gaskets? Under hood tempratures? Looking for 10 HP (b19coupe)
that's interesting, you mean it stayed 20 deg cooler even after extended driving? i've noticed my intake manifold stays cooler after 20 minutes driving, however anything over that and it's scalding hot like it was before i installed the hondata gasket
Old Sep 28, 2007 | 09:26 AM
Default Re: TB coolant bypassed? Insulated Gaskets? Under hood tempratures? Looking for 10 HP (an2ny888)
yeah, thats what im getting at, for the first couple of minutes, the im stays cold but after a pretty long trip 20-30 mins, it feels just as hot as before the Hondata gasket install, but then again, i haven't measured temps with a laser thermometer or digital software.
Old Sep 28, 2007 | 09:57 AM
RNbuilt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">
I have datalogged the difference with/without the Hondata intake gasket on the street. The intake air temps were ~ 20 degrees cooler with the Hondata gasket.</TD></TR></TABLE>
how long was the car been driven on the street?
Old Sep 28, 2007 | 02:20 PM
b19coupe's Avatar
Default Re: TB coolant bypassed? Insulated Gaskets? Under hood tempratures? Looking for 10 HP (NAB18CR)
The car was driven extensively streets, freeway, stop and go. Temperatures under similar conditions were then compared.
For instance-intake temps at a steady 70 MPH cruise.
Old Sep 28, 2007 | 05:35 PM
So then that equate to like a 2% HP increase then right? Isn't a 10 degree decrease in air temp eqaul to about a 1% HP increase?
Old Sep 28, 2007 | 06:19 PM
Yea,
What kind of hp difference do you think you got from that? Just curious?
Old Sep 28, 2007 | 08:26 PM
SIC_jdm_da9's Avatar
i did it but i bypassed the tb im and i would say feels more smoother... but thats me
Old Oct 1, 2007 | 06:05 PM
Default Re: (SIC_jdm_da9)
Header installed, going to test before I wrap it. I'll let you know the difference.
holmesnmanny
Jun 9, 2012 11:33 AM
meccA's eg6
Honda S2000
Sep 5, 2007 04:31 PM
OMG WTF
Apr 14, 2006 12:38 PM
CRX_1.8T
Nov 29, 2005 07:47 PM
Jammersplace
Mar 26, 2004 02:53 PM
