1995 accord ex help
Old Sep 26, 2007 | 02:56 PM
garzaglass's Avatar
Default 1995 accord ex help
I have about 290000 on this car. the Speedo started acting erratic the last 2 weeks then stopped working completely. The d4 light started flashing but the CEL never came on until now. I shorted out the blue connecter and the CEL light gave a code of 17. The d4 flashed 4 times quickly. I found out the code 17 is the vss sensor so I have ordered one of those but wasn’t for sure if code 4 that d4 is giving was a different issue. is there a separate set of trouble codes for the d4 light? Any help on this would be appreciated.
Old Sep 26, 2007 | 06:27 PM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
Default Re: 1995 accord ex help (garzaglass)
I dunno on an auto but the odomiter and speedo not working is a definet sign of a bad VSS.....fix that and I'll bet a dollar the D4 light will go away..oh congrats on 290xxx miles thats effin bad ***.....
Old Sep 29, 2007 | 11:31 AM
garzaglass's Avatar
Default Re: 1995 accord ex help (I got the CD5 Jeebies!)
thanks. im very proud of it. the only major work i have had to do on it is a new air cond system last year. and the miles are prob really close to 295000 since the odom hasnt been working!
Old Sep 29, 2007 | 11:43 AM
TheMuffinMan's Avatar
He knows where you live!
CEL + Speedo/Odo + no cruise = VSS
Speedo/Odo = Cluster
Old Sep 29, 2007 | 04:54 PM
bowser_cd5's Avatar
ur trannys fucked
Old Sep 30, 2007 | 02:24 PM
Default Re: (bowser_cd5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bowser_cd5 &raquo;</TD></TR><TR><TD CLASS="quote">ur trannys fucked</TD></TR></TABLE>
ur an idiot.....why would his tranny be fooked???
Old Sep 30, 2007 | 04:09 PM
Hammer99ex's Avatar
Default Re: (I got the CD5 Jeebies!)
it might not be "phucked" however the d4 light tends to indicate a fault in one or multiple circuits of the trans.
Old Sep 30, 2007 | 04:26 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
The Code 17 from the Check Engine Light, coupled with the Code 4 from the D4 light generally is the VSS. As previously mentioned, replacing the VSS should resolve the problem.
Refer to link below, and select VSS.
http://techauto.tripod.com/
Nealva
Mar 27, 2017 12:29 PM
riptide
Feb 3, 2017 05:41 AM
VtecGang
Apr 29, 2016 10:58 AM
chazmuska
Jun 12, 2009 04:09 AM
dzminiz
Aug 14, 2007 07:12 AM
