anyone have a JDM ZC cluster?
i am trying to find one because it is easier to wire up than an SIR, i have an 89 and the speedo sender is in a bad spot in the dash.....
if you have one, where did you get it?
[Modified by wreckedhatch, 7:16 PM 6/18/2002]
easier yet is a UK VT cluster. The speedo is cable drive, the tach goes to 9K. Easiest thing to do if you can get one is to swap all the instruments into YOUR cluster housing - tach, speedo, fuel/temp. No wiring.
I've got one in my '91 Civic Si.
tico
Aug 20, 2007 09:57 AM
deanh8
40
Jun 7, 2006 05:08 AM
