How get rear mount bolt?
Old Sep 26, 2007 | 01:45 PM
MidShipCivic's Avatar
Default How get rear mount bolt?
It's really tightly spaced how can I get to it?
Old Sep 26, 2007 | 01:54 PM
Okay let me be more specific .. the rear mount is held on by 3 bolts the rear most bolt how do I get it it it doesnt look like swivel fits.
Old Sep 26, 2007 | 02:43 PM
dubzz24's Avatar
Default Re: (MidShipCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidShipCivic &raquo;</TD></TR><TR><TD CLASS="quote">Okay let me be more specific .. the rear mount is held on by 3 bolts the rear most bolt how do I get it it it doesnt look like swivel fits.</TD></TR></TABLE>
Once you have the intake tube off you should be able to get to them with a regular ratchet and extension no problem.
Old Sep 26, 2007 | 03:21 PM
hondacivic90zc's Avatar
Default Re: (dubzz24)
i used two 6 inch extensions with a 3/8" universal joint at the bottom and then the socket. I must admit it is a pain but can be done.
Old Sep 26, 2007 | 03:29 PM
I CRX I's Avatar
well if your removing the motor, take the whole thing out first then take a hammer and start hitting the mount to the left (passenger side), it should help with loosening the bolt and also make needed clearence for you to work with. if your not removing the engine then you pretty much screwed! try your best to fit an extension in there
Crx Jimmy's Avatar
Default Re: (hondacivic90zc)
take the 2 front ones off and use a hammer to spin the mount to the side a little. use a swivel and an extension and you can reach it easier now.
Old Sep 26, 2007 | 04:28 PM
Thanks guys the engine is not completely installed, so this will be easy for me.
8VEYBEYB
12
Aug 25, 2009 11:01 AM
tree fingers
Jul 27, 2008 08:13 PM
b16a2EBP
Mar 23, 2006 08:40 AM
litlekikr
May 12, 2003 05:30 PM
ragejed
Jul 10, 2002 04:30 PM
