MY 98 CRV has a wheel binding and shake felt in gas pedal and steering wheel while low speed turning
Old Jun 18, 2002 | 09:58 AM
steje09's Avatar
Default MY 98 CRV has a wheel binding and shake felt in gas pedal and steering wheel while low speed turning
When I am doing tight turns, especially to the left, when going very slow there is a binding that is felt through the steering wheel and gas pedal, almost like the break is grabbing. What are the possible causes of this?
Old Jun 18, 2002 | 10:04 AM
kmf0211's Avatar
Default Re: MY 98 CRV has a wheel binding and shake felt in gas pedal and steering wheel while low speed tur
im not to sure but it could be your axle?????
Old Jun 18, 2002 | 10:07 AM
Spade's Avatar
Are you using the stock sized tires?
Old Jun 18, 2002 | 10:09 AM
94CivicSi's Avatar
this might be a better questions for the CRV forum....BUT
Check the inside of the tire and wheel. See if either look like they have been rubbing on something.
It COULD be your axle, but when I tore a CV boot, I let it fail completely before replacing the axle. It clicked and made other wierd noises, but never did it bind, at least not noticably.
Old Jun 18, 2002 | 12:53 PM
qbsi's Avatar
check your cv boot. mine was leaking grease and had to change it.
just take out the front wheel and check for leakage around the axel.
i ordered mine from honda and it only cost me $40.00.
jwagner
Jul 14, 2014 05:25 AM
ITRDC2R
Jun 1, 2007 05:43 AM
jpopson43
Apr 20, 2007 05:41 PM
slkleltlclh
11
Nov 29, 2006 10:27 AM
hondaguyexsi
Aug 19, 2005 02:35 PM
