problem with swaping b18c1 to eg hatch
Old Sep 26, 2007 | 12:12 PM
si209's Avatar
Default problem with swaping b18c1 to eg hatch
hey is there anyone who can help me with my swap..i did everything...i put the b18c1 into my eg hatch..everythings is working...it starts run but once the car move on the road my car start to shake or rattle alot....den a frend of mine is tellin me it can be the driver axel i have to cut it a little and weld it back on..but i'm not sure if i'm suppose to cut it..if you can hell let me know..thank...
Old Sep 26, 2007 | 12:15 PM
crazyguy's Avatar
Default Re: problem with swaping b18c1 to eg hatch (si209)
are u using 94 up integra axles???dude..dont cut and weld axles...
Old Sep 26, 2007 | 12:21 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si209 &raquo;</TD></TR><TR><TD CLASS="quote">hey is there anyone who can help me with my swap..i did everything...i put the b18c1 into my eg hatch..everythings is working...it starts run but once the car move on the road my car start to shake or rattle alot....den a frend of mine is tellin me it can be the driver axel i have to cut it a little and weld it back on..but i'm not sure if i'm suppose to cut it..if you can hell let me know..thank...</TD></TR></TABLE>
hey, your friend is a moron. get rid of his phone number and tell him to stop coming around, SERIOUSLY!
i hate when people say stupid **** like that.
as for your problem. double check you motor mounts, they can be loose.
also, make sure your axles are all the way in the tranny and the spindle. make sure the axles are bolted down properly and you hit in the indent on the axle nut.
if an axle is loose it can cause the problems you are describing. also have you tighten all the lug nuts in your car? a loose wheel will do the same.
and last but not least, do not, and i mean do not cut and weld axles. any axles from a b18/b16 motor will work on your car, whether it's from a integra, civic si, or del sol.
and get rid of your friend he's a douche!
Old Sep 26, 2007 | 12:26 PM
instrument's Avatar
whoever your friend is you should get him to participate in next years special olympics.
Check your axles check your mounts, make sure you tightened and staked your axle nuts, also check your ball joints as well.
94eghatchkiller
May 4, 2015 10:31 AM
2slo2serious
Nov 29, 2006 10:36 AM
big juan
Nov 26, 2005 10:09 PM
Drew M
Jul 19, 2004 09:29 AM
civhatchsi
Mar 30, 2003 07:22 PM
