best oil for my f22 manual tranny?
Old Sep 26, 2007 | 11:09 AM
russianswty's Avatar
Default best oil for my f22 manual tranny?
Ok so the dealer ship uses basically oil with some additives in there.
But engine oil doesnt break down that fast in a trannsmission any ways.
Ok so here are my choices.
Royal Purple, with or without a lil lucas oil additive.
GM syncromesh (dont know if I should use all of it or just half)
Honda's MTF
any other opininions out there.
The tranny works fine, just want to do a flush.
So whats the best stuff to use or whats the best mixture of oils to use?
Old Sep 26, 2007 | 11:30 AM
Bruce Banner's Avatar
Default Re: best oil for my f22 manual tranny? (russianswty)
SYNTEC.
Old Sep 26, 2007 | 11:33 AM
Default Re: best oil for my f22 manual tranny? (Bruce Banner)
so yours telling me that castrol is better than royal purple? are you series and
0 30 weight. I hope thats just a pic and not what you used for the tranny? But if it is let me know the results
Old Sep 26, 2007 | 11:36 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by russianswty &raquo;</TD></TR><TR><TD CLASS="quote">so yours telling me that castrol is better than royal purple? are you series and
0 30 weight. I hope thats just a pic and not what you used for the tranny? But if it is let me know the results</TD></TR></TABLE>
Results?
I've been on syntec for years now.
What are you asking for tranny fluid or motor oil?
Old Sep 26, 2007 | 11:46 AM
TRANNY FLUID and did you seriously put 0w30 weight in your tranny?
Old Sep 26, 2007 | 11:48 AM
Honda MTF.
Old Sep 26, 2007 | 03:14 PM
dxtosirex's Avatar
when i changed my drive shaft i put in standard 10w30 motor oil. ive been running the car for around 10months now with No problem's at all.
Old Sep 26, 2007 | 03:19 PM
CD5SiRHero's Avatar
FFFFUUUUUUUU
Royal purple great product...too pricey though.
Old Sep 26, 2007 | 03:26 PM
EuroKing99's Avatar
Default Re: best oil for my f22 manual tranny? (CD5SiRHero)
Honda MTF
After i changed out my tranny oil and replaced it with Honda MTF, my gear shifts were so smooth, i could shift with just my index finger
Old Sep 26, 2007 | 04:28 PM
ej20_ftw's Avatar
redline also make good products
Old Sep 26, 2007 | 06:25 PM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
Default Re: (ej20_ftw)
any 10w-30 is fine..I have buddies who throw syncrmesh in there but when I drive their cars I can't tell the difference......10w-30 FTW
Old Sep 27, 2007 | 03:39 PM
HDuece2's Avatar
Well I would say GM syncromesh, but honda MTF would be fine, I've just fell into the habbit, that if your going to do it, do it the best you can! GM syncromesh is the best for a good operating tranny, and just as good for a tranny that has a grind.
Old Sep 27, 2007 | 03:42 PM
TheMuffinMan's Avatar
He knows where you live!
Honda MTF is best
Old Sep 27, 2007 | 06:32 PM
Blamm!!'s Avatar
Default Re: (TheMuffinMan)
I have Amsoil Synchro MTF 5W30 in mine. Its very good synthetic.
Old Sep 27, 2007 | 06:59 PM
dxtosirex's Avatar
Default Re: best oil for my f22 manual tranny? (HDuece2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HDuece2 &raquo;</TD></TR><TR><TD CLASS="quote">Well I would say GM syncromesh, but honda MTF would be fine, I've just fell into the habbit, that if your going to do it, do it the best you can! GM syncromesh is the best for a good operating tranny, and just as good for a tranny that has a grind. </TD></TR></TABLE>
sounds like i should get this kind the next time i cange my axle "soon" third is pretty bad. racing is bad.
Old Sep 28, 2007 | 09:10 AM
professorman's Avatar
Default Re: best oil for my f22 manual tranny? (dxtosirex)
I used 10w30 in my tranny before. It didnt feel too bad, but when I switched back to Honda MTF, it felt smoother.
Old Sep 28, 2007 | 01:47 PM
1998_4dr_gsr's Avatar
Default Re: best oil for my f22 manual tranny? (professorman)
Honda MTF every 30k miles
Old Sep 28, 2007 | 01:59 PM
Heat's Avatar
Default Re: best oil for my f22 manual tranny? (1998_4dr_gsr)
Regarding manual transmission fluid changes, I had a few questions ('99 LX 4-cylinder)
a. How much manual transmission fluid do I need?
b. Does the change need to be done on a flat surface, or is having the front up on ramps OK?
c. What type of funnel or tube do you use to get oil into the top bolt hole? Does a transmission funnel fit into it?
Old Sep 28, 2007 | 03:54 PM
egyolk's Avatar
Default Re: best oil for my f22 manual tranny? (Heat)
flat surface just fill till it spills out the filler hole, and Honda mtf for the win
Old Sep 29, 2007 | 11:25 PM
wrenchy's Avatar
I have run both Honda MTF and synthetic 10-30 oil. I noticed no difference between the two (my shop manual says regular 10-30 oil).
I do KNOW synthetic will last longer than "regular" oil in a tranney- builds up acids slower, important because tranney oil stays in much longer than engine oil.
I am very picky about my engine oil (10-30 synthetic), but I can't really see spending the $$$ for the Honda MTF, I really saw zero difference, except for the $$$.
I do dump the oil and change it once a year, not very expensive and very easy to do. Do this and don't abuse the clutch/tranney and it will run forever. Wrenchy
Old Sep 30, 2007 | 07:13 AM
ilikehonda's Avatar
Default Re: best oil for my f22 manual tranny? (Mr Wonderfull)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Wonderfull &raquo;</TD></TR><TR><TD CLASS="quote">honda mtf.
note: the friction modified GM syncromesh is the best **** ive ever used.... FIXED a third gear scratch i had...</TD></TR></TABLE>
x2 i run 1 qt honda, and 1 qt syncromesh.....works great
Old Sep 30, 2007 | 04:54 PM
dxtosirex's Avatar
Default Re: best oil for my f22 manual tranny? (ilikehonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilikehonda &raquo;</TD></TR><TR><TD CLASS="quote">
x2 i run 1 qt honda, and 1 qt syncromesh.....works great </TD></TR></TABLE>
Im going to do an axle swap on Wedday on the drivers side. Since i have a 91 Accord with an intermedied shaft am i going to have to replace the tranny fluid? Also how much for the Honda MTF and the syncromesh per qt??
mydadstruck
Jun 24, 2018 01:15 PM
bukydc5
10
May 8, 2008 08:02 PM
kyle45
17
Feb 26, 2007 12:08 AM
CivicRaping
14
Mar 26, 2005 06:22 PM
yeegsr
24
Dec 25, 2004 08:24 PM
