weird engine noises
Old Sep 26, 2007 | 09:12 AM
andyc_0652's Avatar
Default weird engine noises
I recently put a full exhaust on my Civic SiRII...but now I get this whistling noise like there is some kind of leak. It sounds like it is right under my cab, but I've already went and had my exhaust bolts re-torqued and all. Is this normal? I'm still running lean air/fuel ratio...
Old Sep 26, 2007 | 10:20 PM
Kusai.Nihonjin.Desu's Avatar
Default Re: weird engine noises (andyc_0652)
If you had an exhaust leak, you'd definitely hear it. It wouldn't be whistling. Well I guess it could be whistling @ idle. Most likely you're hearing something else...wind noise, intake, etc.
Old Sep 26, 2007 | 10:29 PM
CivicUtah's Avatar
* B A N N E D *
Default Re: weird engine noises (Nihonjin.Desu)
its a turbo yo!
jk..
could this be cause your belts are too tight as well?
Old Sep 26, 2007 | 11:05 PM
Default Re: weird engine noises (CivicUtah)
I believe belts that are too tight, or too loose, will cause squeeking.
Old Sep 26, 2007 | 11:08 PM
GSR_hatch936's Avatar
wat he said!!!
Old Sep 26, 2007 | 11:15 PM
hondaman1320's Avatar
Default Re: weird engine noises (GSR_hatch936)
Some kind of leak, check and get under there with ur boy hitting the gas, maybe small exhaust leak but will cost you mad power, especially if the engine torqing causes the exhaust to seperate... mount inserts say hi !!!
Old Sep 27, 2007 | 12:28 AM
SLO Sol's Avatar
is it all the time or just when your in the throttle or when you get out of the throttle when do you hear it the most?
Old Sep 27, 2007 | 07:43 AM
andyc_0652's Avatar
Default Re: weird engine noises (D-money 92si)
its not so much a whistling noise, but more of a blowing noise like i could swear to god its an exhaust leak. its louder when i accel quickly.
AguaFina_FB6
Honda Civic (2006 - 2015)
Apr 28, 2016 07:17 PM
kuhwahh
15
Nov 27, 2011 03:41 PM
DmC86
Mar 31, 2010 12:45 PM
jdmsijdm
May 3, 2004 04:01 PM
JM Performance
Jun 3, 2002 06:14 AM
