B20 ground clearence
Old Sep 26, 2007 | 08:09 AM
wrestler72's Avatar
Default B20 ground clearence
Ive tried searching but had no luck. When doing the B20 vtec swap into a crx is there any issues with ground clearence. I have a B16 and its not bad but i know the b20 is a bigger block, and i plan on running a 4-2-1 header, ive had bad luck with the 4-1's ground clearence
Old Sep 26, 2007 | 08:12 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: B20 ground clearence (wrestler72)
Ground clearance will be same, mostly. The fact it's a taller block, means its... taller sits in same way so ground clearance is not anymore an issue.
Old Sep 26, 2007 | 08:13 AM
CRX Toad's Avatar
There is no ground clearance issues with B20, might be some hood clearance though.
Old Sep 26, 2007 | 01:59 PM
skateboard_ej8's Avatar
im hench irl
Default Re: B20 ground clearence (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">There is no ground clearance issues with B20, might be some hood clearance though. </TD></TR></TABLE>
Hood clearance, meaning that huge giraffe intake manifold. I seen that problem before.
Old Sep 26, 2007 | 02:07 PM
nickrps's Avatar
Default Re: B20 ground clearence (esco562)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esco562 &raquo;</TD></TR><TR><TD CLASS="quote">
Hood clearance, meaning that huge giraffe intake manifold. I seen that problem before. </TD></TR></TABLE>
You never use that intake manifold anyways. Either find a stock B18a intake mani or pick up a skunk/blox unit.
zdalunatic
Dec 17, 2007 01:16 PM
skeme1
Mar 16, 2007 12:43 AM
b20 crex
12
Feb 10, 2006 08:57 AM
CRXCrazy123
May 4, 2005 08:21 AM
xd69
Sep 10, 2004 03:48 PM
