Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Honda Civic 2002 EX HeadLight Problem
Old Sep 25, 2007 | 11:03 PM
Kenshinhimurasz's Avatar
Default Honda Civic 2002 EX HeadLight Problem
Hi I just installed my new headlights and when I plugged it in only the left side of the lights would light on. The right side would light up but the light is so dim it would not project out so at night only the left side would light up the street. I thought it was the right headlight but when I checked it on the left side and the headlights did work. So it’s some kind of problem with the connection in the plug of the car, but I don't know how to fix it. I was planning to go to an auto shop to ask them to check it, but not sure how much it would cost, so im posting up this to kind of get some advice, if you can post up any kind of ideas on what happened I would appreciate the help, thank you.
The Headlights are DR JDM Black Housing Twin Halo Projector Headlights, but they do work I checked them its something wrong with the cars headlight plugs, only the right side is not working, the left side is fine, its weird I don't know what to do. The Low and High beams don’t work on the right side only the left side works.
Ken
Modified by Kenshinhimurasz at 1:35 AM 9/26/2007
Old Sep 26, 2007 | 12:05 AM
toyomatt84's Avatar
Sanji
You may want to specify what these "new headlights" are.
Old Sep 26, 2007 | 12:54 AM
Jstans84's Avatar
Is there a loose connection with the wires any where?
and Matt he is probably talking about something like these
http://www.procivic.com/pages-....html
but a cheap knock off version. I have seen random junk from "DR JDM" on ebay.
Old Sep 26, 2007 | 02:24 AM
1llmatic's Avatar
New User
Default Re: (Jstans84)
Check your fuse for the right headlight. This tends to happen with projector headlights.
Old Sep 26, 2007 | 02:26 PM
Default Re: (1llmatic)
Yeah it was the fuse thanks a lot
slammedz6ef
Mar 11, 2008 11:12 AM
bopbop93030
Feb 10, 2008 12:49 PM
