my na oem lsvtec build dyno
Old Sep 25, 2007 | 09:32 PM
reactiondc2's Avatar
Default my na oem lsvtec build dyno
i just got off the dyno with my oem lsvtec build..the whole idea behind the build was to put together something reasonably quick on a smaller budget...i used a bunch of parts that i had laying around in my garage instead of sourcing out better stuff...it consists of
SHORTBLOCK:
-b18a block .030 over(spare i had from another project..machine shop screwed up and bored it to far for my other project)
-gsr crank(didnt have an ls otherwise i woulda used it)
-gsr rods fitted with arp bolts(no machining done at all on them)
-rs machine pr3 piston
-gsr oil and water pumps
-fidanza flywheel
-comp stage 2 clutch
HEAD:
-b16 head i had from a turbo project(already had full supertech valvetrain)zero porting
-pro1 cams with pro series cam gears(+3,+2)
-ebay headgasket with the middle layer removed
-performer x intake mani(i went at it with a dremel lol)
-rpm services 70mm tb i had in the garage
-310cc injectors
-hytech/rage knockoff header with 3 inch exhaust
TRANS:
-its the combo of a couple different broken tannies..gsr 1st and second,b16 3rd,4th,5th
-itr lsd
-m factory 4.9 final drive
RESULTS=208.8whp
overall i was pretty happy with the results especially since the particular dyno is known for reading low(as a point of reference an s2k with an intake and catback put down 177)....
vids
http://s2.photobucket.com/albu...build/
Modified by reactiondc2 at 7:01 AM 9/26/2007
Old Sep 26, 2007 | 03:55 AM
reaction360's Avatar
Default Re: my na oem lsvtec build dyno (reactiondc2)
nice steve, this whole time, i forgot you were running a gsr crank n rods. Thats pretty impressive. now get it to the track before they close down for the winter!
-Zol
Old Sep 26, 2007 | 04:58 AM
KYSI's Avatar
Nil Desperandum
What was used for tuning? Nice job by-the-way!<----runs to do quick inventory of garage
Old Sep 26, 2007 | 05:08 AM
Ryank327's Avatar
Wow that is nice to see seeing as how my LS/vtec build thats in the shop irhgt now has pretty muhc the same internals. Sounds sick to. I was shooting for 190hp so I should be able to get it looking at your graph. Yea how did you tune it?
Old Sep 26, 2007 | 05:45 AM
Default Re: my na oem lsvtec build dyno (Ryank327)
all the tuning was done using crome
Old Sep 26, 2007 | 05:53 AM
gsrob's Avatar
Really nice numbers. How's it run on the street?
Old Sep 26, 2007 | 05:59 AM
Default Re: my na oem lsvtec build dyno (gsrob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrob &raquo;</TD></TR><TR><TD CLASS="quote">Really nice numbers. How's it run on the street?</TD></TR></TABLE>ahh it pulls alright..im a little jaded since im more of a turbo guy though
Old Sep 26, 2007 | 06:11 AM
SlowReaction's Avatar
Not bad steve. Should be a good selling point for the car haha. Finish the evo.
Old Sep 26, 2007 | 06:22 AM
Default Re: my na oem lsvtec build dyno (SlowReaction)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowReaction &raquo;</TD></TR><TR><TD CLASS="quote">Not bad steve. Should be a good selling point for the car haha. Finish the evo.</TD></TR></TABLE>haha exactly i know
Old Sep 26, 2007 | 06:59 AM
401B18TEG's Avatar
nice number.
Old Sep 26, 2007 | 09:03 AM
Chillinit's Avatar
Default Re: (401B18TEG)
Old Sep 26, 2007 | 11:08 AM
4g hatch's Avatar
so you dont have to run oil squirters for gsr rods/crank
Old Sep 26, 2007 | 04:30 PM
Default Re: (4g hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g hatch &raquo;</TD></TR><TR><TD CLASS="quote">so you dont have to run oil squirters for gsr rods/crank</TD></TR></TABLE>
No, the squirters are for the pistons. and alot of guys, like myself actually plug them off on vtec motors.
-Zol
Old Sep 26, 2007 | 04:57 PM
4g hatch's Avatar
Default Re: (reaction360)
you here of alot of people put ls internals in a gsr block,but not the other way around. makes since cause a gsr block can be expensive but a ls can be had for dirt cheap. i have a extra gsr crank laying around hmmmmm
Old Sep 26, 2007 | 05:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g hatch &raquo;</TD></TR><TR><TD CLASS="quote">you here of alot of people put ls internals in a gsr block,but not the other way around. makes since cause a gsr block can be expensive but a ls can be had for dirt cheap. i have a extra gsr crank laying around hmmmmm </TD></TR></TABLE>if i had my choice i woulda used an ls crank in it personally,i just used the gsr crank because i had it laying around and didn't wanna spend money on sourcing out another ls crank...i already blew the budget bad enough without that extra cost lol
Old Sep 26, 2007 | 05:37 PM
Combustion Contraption's Avatar
ssso.....
its not really an LS/VTEC now is it?
Anyway, good looking numbers. What engine management was used ?
Old Sep 26, 2007 | 05:44 PM
Default Re: (Combustion Contraption)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption &raquo;</TD></TR><TR><TD CLASS="quote">ssso.....
Anyway, good looking numbers. What engine management was used ? </TD></TR></TABLE>well its an ls block with a vtec head so id say yes it is........crome tuned
Old Sep 26, 2007 | 05:46 PM
what makes an LS/VTEC is the 89mm crank, not just the block stamping.
Old Sep 26, 2007 | 05:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption &raquo;</TD></TR><TR><TD CLASS="quote">what makes an LS/VTEC is the 89mm crank, not just the block stamping. </TD></TR></TABLE>so then i guess the last gsr motor i built with an 89mm crank was an lsvtec then...what would you call a sleeved out ls with a stroker crank and a vtec head then?...lets just agree to disagree
Old Sep 26, 2007 | 05:53 PM
Default Re: (reactiondc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reactiondc2 &raquo;</TD></TR><TR><TD CLASS="quote">so then i guess the last gsr motor i built with an 89mm crank was an lsvtec then </TD></TR></TABLE>
yes
Old Sep 26, 2007 | 05:56 PM
yes</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reactiondc2 &raquo;</TD></TR><TR><TD CLASS="quote">...lets just agree to disagree </TD></TR></TABLE>
Old Sep 26, 2007 | 05:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reactiondc2 &raquo;</TD></TR><TR><TD CLASS="quote">Yea, now that i think about it, youre right, CC. It really isnt an ls/vtec</TD></TR></TABLE>
Old Sep 26, 2007 | 06:01 PM
ok yes you are right and im wrong</TD></TR></TABLE>lol
Old Sep 26, 2007 | 06:03 PM
HAH! everyone in this forum will know thats b.s. because i never admit when im wrong.
Anyway, ill end this here. Nice build.
Old Sep 26, 2007 | 06:06 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption &raquo;</TD></TR><TR><TD CLASS="quote">HAH! everyone in this forum will know thats b.s. because i never admit when im wrong.
Anyway, ill end this here. Nice build.</TD></TR></TABLE>thnx ...the only reason i posted about the build is because i was pleased how well it went for such a mild setup..def not to argue about what type of motor it was...we will just call it a b series oem style build now haha
