What intake on CRX with B16?
Old Jun 18, 2002 | 08:56 AM
REDBARON's Avatar
Default What intake on CRX with B16?
Well I did a search and found nothing. So here it goes.
What intake are you guys using with your B16CRX? IE..94 del sol, CRX Si?
Thanks.
Old Jun 18, 2002 | 09:37 AM
spettinger's Avatar
Default Re: What intake on CRX with B16? (REDBARON)
same as CRX SI or hatch SI
Old Jun 18, 2002 | 10:03 AM
SuperCivic's Avatar
i heard the integra one will fit. i'm using a modified iceman that i had to cut myself..
Old Jun 18, 2002 | 10:09 AM
Lsos's Avatar
Don't use a crx one. Some guy posted a while ago about much greater power gains from a b16 intake. I guess the diameter is bigger than on a standard crx intake. He did have fitment issues though, as in he had to move the battery. Nevertheless, either use a b16 intake, such as the '99 Civic SI, or don't waste your money.
REDBARON's Avatar
Default Re: What intake on CRX with B16? (SuperCivic)
Are those intakes the same diameter as the DOHC VTEC ones?
Old Jun 18, 2002 | 10:26 AM
big pete's Avatar
99 civic si....diameter is bigger than the crx one
Old Jun 18, 2002 | 10:56 AM
REDBARON's Avatar
Default Re: What intake on CRX with B16? (big pete)
Will I have fitment issue?
Old Jun 18, 2002 | 11:00 AM
SuperCivic's Avatar
yes.
i had purchased the ICEMAN "b16 in crx" intake and guess what..it was just a straight pipe. it sucked. didn't clear the battery. i had to get iceman to send me the crx one, then i had to cut and paste, so i had the bend for the battery and the larger opening at the throttle body.
Old Jun 18, 2002 | 11:04 AM
marty's Avatar
INJEN cai - bolt on
Old Jun 18, 2002 | 11:06 AM
REDBARON's Avatar
Default Re: What intake on CRX with B16? (MugenEF7)
For which car? The CRX, Si,? Is it the same diameter as the B16 intakes are?
Old Jun 18, 2002 | 11:07 AM
marty's Avatar
CRX Si/EX same size.
Old Jun 18, 2002 | 11:09 AM
SuperCivic's Avatar
INJEN cai - bolt on
that's right..and it's polished 3 inch isn't it??
Old Jun 18, 2002 | 11:10 AM
marty's Avatar
absolutely
REDBARON's Avatar
I was referring to the 99Si, and CRX Si. Is the Injen intake the same diameter in size for both applications? And will it bolt onto a B16 CRX?
Old Jun 18, 2002 | 11:15 AM
marty's Avatar
get the INJEN CRX Si/EX CAI. the 99si will probably not fit properly
Old Jun 18, 2002 | 11:16 AM
REDBARON's Avatar
Ok, Thanks.
Old Jun 18, 2002 | 11:22 AM
02WRX's Avatar
i plan on using my AEM CAI on the b16 - with the setup being a two piece, i figure i shouldn't have any major problems with fitment & the intake is plenty big enough!
eric
Old Jun 18, 2002 | 05:54 PM
StorminMatt's Avatar
Default Re: What intake on CRX with B16? (90CivicEX)
The 1999-2000 SI AEM CAI is best. There is the issue of the battery, though. I believe the best way to deal with this is to get an Odyssey battery. Not only does it allow room for the intake. But it also drops weight by about 15 pounds and does not require relocation.
Old Jun 18, 2002 | 06:04 PM
3RROR404's Avatar
Default Re: What intake on CRX with B16? (StorminMatt)
Battery boxes aren't that bad of an idea either, I got mine for about 100$ w/ wires. Little bit more weight in the back for my FF drift sessions, aka *** draggers anonymous.
Old Jun 18, 2002 | 06:21 PM
Lsos's Avatar
Aah...you're the "some guy" I was referring to a couple posts up.
VegaS10
Apr 14, 2006 09:29 AM
crxh22project
Feb 9, 2005 11:57 AM
type Gendy
15
Sep 9, 2003 09:02 PM
K_1
17
May 29, 2002 11:12 PM
EFing8
Jan 25, 2002 01:52 PM
