NEED HELP! H22 swap and Vtec dosn't work!!
I did a h22 swap into a 93 Honda Accord!
I took an H22 ECU and ran new wires to it from the V-tec to the ECU, but my motor still cuts of @ 6800 rpm!
What shod I do??
PLZ HELP
What shod I do??
PLZ HELP
make sure the pinouts are correct, make sure it is grounded properly, make sure your battery is not bunk, make sure the solenoid screen is clean, make sure you have enough oil. just some general advice, im having a similar problem with my 96 accord h22.
Does the car run good up 6800 rpm? If not, you might want to check the TPS & Map sensor, they could be hooked up in reverse as they are similar plugs and will plug into each other. I've seen a few people do this honest mistake!
i thought the ECU dose that!!
But I wont to get a different one since I took my egr valve of I need one with a chip in it!!
Modified by RooSter at 6:00 PM 11/18/2007
JDM-CD5H22
Oct 18, 2007 03:22 PM
