Tranny Swap
im lookin to convert a 1997 honda prelude with an automatic transmission to one with a manual tranmission. can someone tell me what specific tranny i'll need and how much itll set me back. i'm planning on doing the labor myself. any websites that carry the tranny and all its components would be appreciated.
thanks fellas,
-AR
thanks fellas,
-AR
here...before they jump all over you for not searching....
good luck man....
List of Parts:
Helms Manual (VERY IMPORTANT) Helm Inc
Transmissions Assembly (97+)
Trans mounts-side
Engine Mount-rear (rear is optional-the rear auto mount will work)
Flywheel and bolts
Clutch Kit and bolts
Clutch Master Cylinder
*Clutch Slave Cylinder
*Clutch Dampener
*Vehicle Speed Sensor (VSS)
*Reverse Switch
*Hydrolic Lines
*5spd Starter
Clutch Pedal Assembly
Brake Pedal Assembly
Shifter Assembly
Shift linkage
Auto ECU or 5speed ECU
5spd Intermediate shaft (half-shaft)
5spd Gauge Cluster (optional)
Cotter Pins (assorted sizes)
Assorted Nuts and Bolts
* MOST LIKELY THESE WILL BE ATTACHED TO TRANNY (DOUBLE CHECK)
**This list of parts consistes of the main components needed and does not include every little nut, bolt, and bracket. You get the idea.
good luck man....
List of Parts:
Trans mounts-side
Flywheel and bolts
*Clutch Dampener
*Reverse Switch
*Hydrolic Lines
*5spd Starter
Shifter Assembly
Shift linkage
draneusmc
Jul 24, 2003 11:15 PM
