Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Front control arm bushing replacement
Old Sep 25, 2007 | 04:00 PM
AccordEX1991's Avatar
Default Front control arm bushing replacement
How tight are the bushings on the control arm?
No problem with the old one, I'll just destroy them.
Question is, do I need to press them in?
Thanks.
Old Sep 26, 2007 | 07:52 AM
skipbarber's Avatar
you have to use a press, 20 ton with the right adapter worked for us twice, we tried it again on boilermakers LCA's and i almost got a concussion out of it. It seems if they're seized in there, they aint comin out without a fight, boiler ended up just buying new LCA's, but we still have to figure out how to get the old ones done. either have a shop do it, or be very careful.
Old Sep 26, 2007 | 08:01 AM
Default Re: (skipbarber)
Ouch, that hurts.
Got the old ones out already. Sawzall the rubber and steel sleeve. Came out with no fight.
Now I just have to press them in. Maybe heat up the control arm then slide in the new bushing?
We'll see.
Thanks.
Old Sep 26, 2007 | 08:59 AM
skipbarber's Avatar
pressing the energy suspension bushings is really easy, just lube it up and push them in.
Old Sep 26, 2007 | 03:07 PM
Still waiting on parts.
Here is a pic of the old suspension bushing.
Old Sep 26, 2007 | 04:39 PM
s13_240sx_92's Avatar
Default Re: Front control arm bushing replacement (AccordEX1991)
another thing you can try is to hit it with a torch and burn/melt out the old bushing..
I know it works for other bushings.
Old Sep 26, 2007 | 06:26 PM
nickEM2slo's Avatar
i made a thread about this a while back. it is so much easier if you press them in. heating them up is a pain in the ***.
Old Sep 29, 2007 | 11:09 AM
Default Re: (nickEM2slo)
Bushing pressed in with no fight. Used a hydraulic press.
Old Oct 4, 2007 | 04:16 AM
Jackson123's Avatar
Default Re: (AccordEX1991)
Where can i get a front control arm for an integra? i have looked all over this site, and this is the only thread with front control arm
Old Oct 5, 2007 | 02:45 AM
Default Re: (Jackson123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jackson123 &raquo;</TD></TR><TR><TD CLASS="quote">Where can i get a front control arm for an integra? i have looked all over this site, and this is the only thread with front control arm</TD></TR></TABLE>
search online.
example: http://www.acuraautomotivepart...ormal
Old Oct 19, 2007 | 11:45 AM
InanimateCarbonRod's Avatar
Hey,
How big of a press did you use to push that bushing in?
Honda wanted $600 to replace this bushing on both sides. It would have been $643 if they replaced both control arms as a whole (less labor, more parts cost).
Needless to say, I'm now looking into doing it myself.
Old Oct 19, 2007 | 04:40 PM
skipbarber's Avatar
my cost on 2 brand new LCA's from the dealer was a bit over $120, i dont know what retail is on that, but im sure it'd be almost double if not more. the first two times i did it. i did it with a 20 ton press.
Old Oct 19, 2007 | 07:12 PM
Woah. The dealer said the control arms were $149 EACH. Maybe they only had the gold plated ones in stock.
I'm going to talk with a guy this weekend's autox to see if he can help me out. He's the parts manager at a different Honda dealer.
Thanks for the info on the press. I may get one in the future, regardless of how I replace these bushings. I've been pestering the wife about getting an '89 Si.
Old Oct 24, 2007 | 09:34 AM
Default Re: (InanimateCarbonRod)
Getting new control arms. Can anyone tell me what the torque specs are for the three bolts/nuts.
Old Oct 24, 2007 | 11:15 AM
rushbuster70's Avatar
how do we know when these need to be replaced?
Old Oct 24, 2007 | 01:54 PM
skipbarber's Avatar
easiest thing to do if your steering doesnt give it away is to jack up the car, take off the front wheels and look at them. you can usually see where the bushing has seperated from the casing.
Old Apr 14, 2008 | 09:17 AM
JoJo818's Avatar
Default Re: (rushbuster70)
Did you ever get the info on this? I need to replace one of my bushings and I need this info as well.
Old Apr 14, 2008 | 09:29 AM
JoJo818's Avatar
BTW, if anyone else needs to replace a bushing I would suggest taking it to Napa if they have a machine shop. There's one in my area and replacing it will cost me $35.
Old Apr 14, 2008 | 09:32 AM
Mikebdagr8's Avatar
replaced both of mine for 125 at my mechanic
Old Apr 14, 2008 | 11:35 AM
toyomatt84's Avatar
Sanji
Default Re: (JoJo818)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoJo818 &raquo;</TD></TR><TR><TD CLASS="quote">Did you ever get the info on this? I need to replace one of my bushings and I need this info as well.</TD></TR></TABLE>
They're called "compliance bushings".
https://honda-tech.com/zerothread?id=2231997
axis11
Suspension & Brakes
Mar 9, 2012 09:21 AM
sshiny007
20
Oct 28, 2009 06:49 AM
oldskool88291
Dec 10, 2007 04:48 PM
thisboyjulio
Oct 23, 2006 08:34 PM
