Suspension & Brakes Theory, alignment, spring rates....
tein ss from crx to ek coupe
Old Sep 25, 2007 | 02:31 PM
olddohc's Avatar
Default tein ss from crx to ek coupe
im selling a set of tein super street coilovers from my 91 crx and this guy wants to buy them for his 2000 coupe, will this work? thanks guys and to be politically correct, thanks girls too
Old Sep 26, 2007 | 09:46 AM
Rdriver's Avatar
Default Re: tein ss from crx to ek coupe (olddohc)
The fronts will work the rears will not. The EK rear struts have forks that go over the LCA's, CRX uses ITR style rear LCA's.
Old Sep 26, 2007 | 01:33 PM
olddohc's Avatar
Default Re: tein ss from crx to ek coupe (Rdriver)
thanks
Old Sep 26, 2007 | 07:02 PM
Targa250R's Avatar
be professional
The fronts won't work either unless he uses the '88-91 Civic/CRX lower mounting forks. The fork diameter is smaller than '92-00 models.
The rears actually will work if used with a spacer to adapt the wider CRX damper fork to the narrower '96-00 bushing. Only the '88 CRX uses the eye-style rear lower damper mount and "ITR-style" rear lower control arms. '89-91 models use a fork-style rear lower damper mount with the ubiquitous beam-style control arm.
Old Oct 17, 2007 | 03:38 PM
llozll's Avatar
how'bout to 95 gsr?
will it require itr lca?
Old Oct 18, 2007 | 12:16 PM
Targa250R's Avatar
be professional
Default Re: (llozll)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by llozll &raquo;</TD></TR><TR><TD CLASS="quote">how'bout to 95 gsr?
will it require itr lca?</TD></TR></TABLE>
'89-91 CRX rears will bolt right up. However, they are shorter than the stock Integra dampers.
The fronts will require '88-91 Civic/CRX lower mounting forks.
Old Oct 18, 2007 | 08:22 PM
ClubRX's Avatar
Default Re: (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
The fronts will require '88-91 Civic/CRX lower mounting forks.</TD></TR></TABLE>
How much shorter in the rear? has any1 done this b4?
EF Two.
13
Nov 21, 2006 01:50 AM
mike84 CRX-GTL
Sep 27, 2004 05:46 PM
Wicked_CRX
15
Oct 6, 2003 04:25 PM
Wicked_CRX
Aug 25, 2003 02:49 PM
inFamousOneSix
Mar 12, 2003 02:20 AM
