98 civic oil pan torque
Old Sep 25, 2007 | 12:27 PM
yesSiReK's Avatar
Default 98 civic oil pan torque
so anyone know what i should torque my oil pan gasket at? got a 98 civic dx d16y7. send me a link or anything thanks
Old Sep 25, 2007 | 02:20 PM
TahitianEG's Avatar
Default Re: 98 civic oil pan torque (yesSiReK)
I think that the torque on the oil pan is the same for the d series as it is for the B. If that is the case, I know that the B series oil pan is torqued to 9 ft lbs.
Seems like it wouldn't be enough, but that's what I've read out of a Del Sol Mechanics manual
Old Sep 25, 2007 | 02:27 PM
n8dizzel's Avatar
Honestly i take a 3/8 ratchet and with my hand a little less than half way up give it a good turn to tighten it up. changed my oil plenty of times and never damaged the threads in the pan and never drip any oil out the plug.
Old Sep 25, 2007 | 02:31 PM
fdavie's Avatar
Default Re: 98 civic oil pan torque (n8dizzel)
oil pan gasket, not the drain nut.
Old Sep 25, 2007 | 02:35 PM
Syndacate's Avatar
Default Re: 98 civic oil pan torque (TahitianEG)
8.7lb/ft // 12N-m
5 1 3
6 2 4
Don't forget to apply liquid gasket to the edges of the "humps" on each end of the gasket.
- Right outta the helms manual
PS: 1 is right next to the drain plug.
Old Sep 25, 2007 | 02:37 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n8dizzel &raquo;</TD></TR><TR><TD CLASS="quote">Honestly i take a 3/8 ratchet and with my hand a little less than half way up give it a good turn to tighten it up. changed my oil plenty of times and never damaged the threads in the pan and never drip any oil out the plug.</TD></TR></TABLE>
Doesn't really matter worth of crap what you torque the drain plug at as long as it's about 2/5 a turn past "finger tight."
Old Sep 25, 2007 | 03:08 PM
yesSiReK's Avatar
sounds good now i gotta find someone with a torque wrench thanx dudes
Old Sep 25, 2007 | 07:10 PM
n8dizzel's Avatar
Default Re: 98 civic oil pan torque (fdavie)
oops heh, sry. my bad.
Old Sep 25, 2007 | 07:12 PM
jdm91CrxSi's Avatar
**** i just tightend mine till i couldnt turn it no more.. i think it was like 210ft/lbs
Old Sep 26, 2007 | 05:16 PM
yesSiReK's Avatar
Default Re: 98 civic oil pan torque (jdm91CrxSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm91CrxSi &raquo;</TD></TR><TR><TD CLASS="quote">**** i just tightend mine till i couldnt turn it no more.. i think it was like 210ft/lbs</TD></TR></TABLE>
0_0 bad...
san_luis
Mar 22, 2010 10:09 AM
ridewhencan
Jan 24, 2005 10:29 PM
Si Shane
10
Dec 13, 2004 05:35 PM
FUP23
Aug 8, 2002 07:05 AM
