Mr. Gaskets, bolts fittings and more low prices
I have a ton of Mr. Gasket stuff that I am selling if anyone wants to buy large amounts I can give them a great deal let me know if you have any questions.
(2) 6087 Oil pan bolts Ford 289-351w AMC and old V8s $4.00
(2) 6710 Flex plate bolts GM 7/16-20x 11/16 grade 8 $4.00
954G Intake Bolts 396-354 3/8-16x1-14 16psc. $4.00
6086 oil pan bolts chevy 396-454 all Pontiac V8s $4.50
2557 Water Neck with o-rings SB chevy with ½ vac. Hole $3.00
(2) 911 Pres. Plate bolts Ford 5/16-18x1 Grade 8 6pcs. $3.00
1933 Carb adapter kit fits most 4 bolt 2bbl and 4bbl. $10.00
3413 Header to muffler bolt kit 3/8-16x1 grade 5 $2.00
(2) 1932 Carb adapter kit fits most 4bbl. Carbs $12.00
(2) 3706 Rubber Grommet assortment $10.00
6715 torque converter bolts GM 3/8-16x1/2 Grade 8 3pcs. $3.50
(3) 995G Intake manifold bolts SB chevy, Mopar, AMC
(3) 912 Flywheel bolts chevy/fod 7/16-20 31/32 grade 8 $5.00
(5) 3704 Vaccum Caps $3.00
6085 Self locking oil pan bolts SB chevy old V8s 18pcs. $6.00
60 Carb stud 1 ½ length $3.00
(6) S6 Straight swivel-6 fitting $6.00
(2) 62 Carb. Stud 5/16x 1-1/2 4pcs. $4.00
6715 Torque convertor bolts GM 3/8-16x1/2 Grade 8 3pcs. $4.50
(2) 910 Pres. Plate bolts GM and Mopar 3/8-16x1 grade 8 6 pcs. $4.00
(2) 945G Harmonic blalancer bolt 3/8-16-1 $2.00
(2) 916 Header bolts Grade 8 socket head 3/8-16x3/4 $5.50
5332 Carb Knurl Nuts 5/16 studs $5.00
(2) 68816 Skull license plate bolt kit $3.00
(2) 9882 Valve cover tabs 8 tabs ¼-20 bolts $3.00
(2) 6304 Valve cover acorn nuts come plated steal ¼-20 $12.00
(2) 958G Intake manifold bolts ford 260-289-302-351w $5.00
(2) 915 Header bolts grade 5 Hex head 3/8-16x3/4 $3.00
3416 Header bolt lock washers $2.00
946G Crank bolt 396-454 Cevy $3.00
2043 Vent Breather 3/8 tube $3.00
16 Nylon Washer Fits ½ oil pan $2.00
millionhari
Jul 22, 2013 09:46 PM
pliskin679
Sep 14, 2007 06:57 PM
