Skunk2 stage2 cams (B18c)
i have plenty of experience with these cams altho not on a stock i suppose B18c...but in LSvtec with 13.1comp, GSR with 12.8.1comp no problem at all at track and on street... ****, i even threw the cams in my stock b16a("EDITED" but i was using supertech valve springs/ti retainers) drove it from Fresno to San Diego and back 12Hr road trip with no freaken problem..... Good cam for a street car IMO..
-Kevin
Modified by b20vtech at 2:57 PM 9/25/2007
-Kevin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sherdog9 »</TD></TR><TR><TD CLASS="quote">Do anyone have problems with these cams? Do they effect your daily driving?</TD></TR></TABLE>
If you don't strengthen your valvetrain first, they can....because you'll be walking to work when you blow the thing up. This = no more "daily driving".
these are actually very good cams. I've seen them run for a little over 2 years on a stock gsr head. The car was at one point revving to 9k without a single problem from the cams. While I wouldn't recommend revving a stock gsr to 9k it just goes to show that these cams are very successful in most near stock setups and can take the abuse.
ps. They are still mild enough to run stock valvetrain. Just maintain factory redline.
i had pro 2 skunk cams on my ek and they werent that bad. Idle was a bit lumpy and i was getting about 22mpg which aint bad since i was beating on it like crazy. I know they aint stage 2's put just as good for a dd if tuned right .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teh hatton »</TD></TR><TR><TD CLASS="quote">They are still mild enough to run stock valvetrain. Just maintain factory redline.</TD></TR></TABLE>
No.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk2 »</TD></TR><TR><TD CLASS="quote">what is required for a Stage 2 camshaft upgrade are stronger valve springs and retainers. We also recommend a fuel pressure regulator and a vtec controller to optimize the results.</TD></TR></TABLE>
Just because a couple of people get away with it does not make it a good idea.
No.
ps. They are still mild enough to run stock valvetrain. Just maintain factory redline.</TD></TR></TABLE>
Horrible advice. Lift doesn't vary with RPM's (in vtec).
Modified by bambam at 11:39 AM 9/27/2007
oh btw, I have skunk2 stage1 cams + skunk2 valvetrains, but the car did not put down much HP even with good tune (~170whp). I want something more and street suitable.
I have them in my built head and it works just great i love it especially after 5200 it haullls ****! Buttt Im thnink about going to pro 1s because im at 11.9 comp and I wanted to try something else
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sherdog9 »</TD></TR><TR><TD CLASS="quote">Will i see any difference to switch from skunk2 stage 1 cams to skunk2 stage 2 cams?</TD></TR></TABLE>
big difference
big difference
ull pick up some more peak horsepower. midrange should be pretty decent being the primary lobes on the non pro series cams arent anything big.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaCivicSiR1 »</TD></TR><TR><TD CLASS="quote">how are s2s1 on a stock b series ecu example p61?</TD></TR></TABLE>
if ur trying to say u dont want to get a tune that im gonna tell u dont even bother getting the cams. everything needs a tune especially cams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cartune network »</TD></TR><TR><TD CLASS="quote">
if ur trying to say u dont want to get a tune that im gonna tell u dont even bother getting the cams. everything needs a tune especially cams.</TD></TR></TABLE>well i know 75-80%of everyone has chipped ecu's on here but i love the p61 ecu on my gsr motor
I have S2S2 waiting to go into my car. My question is, how high can you take them until you stop making usable power. And where should I expect them to be most aggressive? The mid to high range?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OC Geezer »</TD></TR><TR><TD CLASS="quote">I have S2S2 waiting to go into my car. My question is, how high can you take them until you stop making usable power. And where should I expect them to be most aggressive? The mid to high range?
we wont know unless you dyno em.
</TD></TR></TABLE>we wont know unless you dyno em.
216.226.142.95:27016
33
Jun 17, 2003 09:23 AM
