98' Spec JDM ITR Dyno result
Old Sep 25, 2007 | 08:48 AM
yoorang's Avatar
Default 98' Spec JDM ITR Dyno result
Here is my dyno chart for my 98' Spec JDM ITR and the mod list as below:
- PasswordJDM Intake
- SMSP Cat. Converter
- Maxbore ITR Throttle Body
- Rest are all bone stock
- Hondata S100 + P28
- Tuned by SGT
Would you rate this as a decent / health ITR motor?
Old Sep 25, 2007 | 08:51 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: 98' Spec JDM ITR Dyno result (yoorang)
Based on the dyno, yes, I would say this is in very good shape. What does the A/F look like?
Old Sep 25, 2007 | 09:25 AM
DJ_NeX's Avatar
I like those results. If my JDM ITR puts that out when I drop it in, I'll be VERY happy.
Old Sep 25, 2007 | 02:17 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: 98' Spec JDM ITR Dyno result (DJ_NeX)
That's healthy, now get rid of that intake and replace it with an AEM Type R cai and make some more power
Old Sep 25, 2007 | 02:23 PM
4g hatch's Avatar
Default Re: 98' Spec JDM ITR Dyno result (00Red_SiR)
what exhaust do you have? can u get the a/f graph. did he adjust the cam gears.
i would say it looks like a healthy r
Old Sep 25, 2007 | 02:27 PM
MikeySpec's Avatar
Do you have this graph in RPM? I'd like to see where that torque spike is coming from.
Old Sep 25, 2007 | 09:29 PM
mtber's Avatar
Looks good to me.
Old Sep 25, 2007 | 10:43 PM
n1_egsex's Avatar
* B A N N E D *
Default Re: 98' Spec JDM ITR Dyno result (mtber)
what size throttle body are you using?
and i assume you have the jdm 4-1 header
what about exhaust system?
Old Sep 26, 2007 | 12:21 AM
98vtec's Avatar
moderator emeritus
Default Re: 98' Spec JDM ITR Dyno result (n1_egsex)
wow. Nice midrange
post this in the dyno registry please
Old Sep 26, 2007 | 05:33 AM
neophyte210's Avatar
Default Re: 98' Spec JDM ITR Dyno result (Evil.98vtec)
good #'s
Old Sep 26, 2007 | 11:12 AM
Mr.OB*GYN_Rhett's Avatar
im assuming its a stock catback
Old Sep 26, 2007 | 11:20 AM
yoorang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n1_egsex &raquo;</TD></TR><TR><TD CLASS="quote">what size throttle body are you using?
what about exhaust system?</TD></TR></TABLE>
it's just 68mm outlet, 65mm inlet, and jdm 4-1 header with smsp cat. converter and stock itr exhaust system
Old Sep 26, 2007 | 02:44 PM
4g hatch's Avatar
smsp header,and a 2 1/2 exhaust would be a great addition. do you have adjustable cam gears,did he adjust them? also im in va also who/where did u get your tune done at. im gonna need one for my ls-v soon. oh yeah like everyone else said thats a strong motor
Old Sep 26, 2007 | 03:26 PM
Gong Show's Avatar
Default Re: 98' Spec JDM ITR Dyno result (4g hatch)
I'm liking these numbers recently on these stock R's, and simple gsr builds.
Old Oct 5, 2007 | 09:22 AM
filipedua's Avatar
Hi yoorang
Just curious if you remember your cam pulleys settings in your jdm b16 with spec A's?
I'm from portugal and running very similar setup.
Thanks in advance
Old Oct 5, 2007 | 09:33 AM
Rocket's Avatar
Default Re: (filipedua)
Your torque number is most likely off. Coud be a misfire at the spike. Notice how at the torque spike power does not incease.
Dynojets read power directly and then computes torque using the rpm signal taken from the spark plug wire. If you have a misfire it thinks the motor is turning slower and computes a higher torque number.
Either way, the motor is very healthy
EFhothatch15
Jul 8, 2009 11:07 PM
erikiksaz1
May 11, 2006 06:45 AM
hybrid69
Feb 16, 2005 12:06 PM
Twin-cam
Jun 15, 2004 01:46 PM
S&P500ITR
Dec 24, 2001 07:38 AM
