>>>PLEASE Help Me!! <<<
Old Sep 25, 2007 | 07:10 AM
Soon2bH2b's Avatar
Default >>>PLEASE Help Me!! <<<
I need help and have no clue what to do!
So i was redoing my whole coolant system and i took off the aluminum part that bolts into the block. (The that the line/house goes on) When i did both bolts broke and where stuck in the block.
So i tried to use an E-Z out/pro-grip. Had no luck at all. I then tried to drill out the bolt, planning on re-threading/using a threaded insert. And of coarse no luck again.
so i let my brother try while i run to the hardware store. When i got back he had tried drilling out the bolts. And on the one hole (top one) He drilled under the where the broken bolt is into the block and i have no clue why but he drilled one by the other hole too that's no where close to the original. SO is there any other ways to get that piece to stay on there??
I thought about jb weld? but idk if is strong enough
Please help me.
Old Sep 25, 2007 | 07:18 AM
FastCougar's Avatar
Default Re: >>>PLEASE Help Me!! <<< (Soon2bH2b)
As long as you can get the original bolts out, I would get it welded shut and then drilled and retapped.
Old Sep 25, 2007 | 07:41 AM
Soon2bH2b's Avatar
Default Re: >>>PLEASE Help Me!! <<< (FastCougar)
I can't get them out.
Old Sep 25, 2007 | 08:49 AM
RC000E's Avatar
post a pic....I think that'd work better
Old Sep 25, 2007 | 09:16 AM
Soon2bH2b's Avatar
Default Re: >>>PLEASE Help Me!! <<< (RC000E)
I don't have camera currently since it got stolen.
So would jb weld work or is there something similar that will?
Old Sep 25, 2007 | 02:28 PM
locash's Avatar
Remove head and take it to a shop with a wire EDM, then repair as necessary.
Do NOT use JB weld.
Old Sep 25, 2007 | 03:32 PM
FastCougar's Avatar
Default Re: >>>PLEASE Help Me!! <<< (locash)
Why would you use JB weld if you still haven't gotten the bolt out ... removing the bolt is critial. I would then recommend welding the bolt hole shut and then drilled and tapped in the stock location.
sammyb20
Mar 1, 2009 07:30 PM
Soon2bH2b
Sep 26, 2007 05:43 AM
Soon2bH2b
Sep 25, 2007 10:09 AM
Soon2bH2b
Sep 25, 2007 08:29 AM
Homotor
Apr 20, 2007 02:11 PM
