idle rough
Old Sep 24, 2007 | 09:37 PM
91highryda's Avatar
Default idle rough
just got done doing an ls swap and my car idles rough... i hooked up all the vacumm lines up and still a rough idle.. i got new dist.,spark plugs,wires, almost everything i can think of is new..can any1 help me out by chance... thanks brandon
Old Sep 25, 2007 | 08:01 AM
wiZCo's Avatar
Stouts 'n' Scotch
Do you have any CELs?
Is the idle speed set correctly? TPS calibrated properly?
Old Sep 25, 2007 | 09:58 PM
91highryda's Avatar
Default Re: (wiZCo)
no check engine light at all
Old Sep 26, 2007 | 04:58 PM
konka's Avatar
Default Re: (91highryda)
check and make sure all ur ground wires are clean and connected. check the little boxes on each side of the engine compartment, they should be right by the lights on eachside. make sure they are clean and rust free. then try it. I had the same problem b4. I i couldnt figure out why it was idling badly. lceaned all the grounds and poooooffffff. perfect idle. keep me posted.
jdm_insider
Sep 21, 2012 04:17 AM
sick_dc2
Jul 8, 2008 12:02 PM
easycheese
Jan 14, 2008 10:04 AM
whitediamond642
Apr 10, 2007 04:37 AM
JDM90SiR
Jan 27, 2005 08:58 PM
