Suspension & Brakes Theory, alignment, spring rates....
will coilovers off an integra fit a civic
Old Sep 24, 2007 | 09:23 PM
ej8fasho's Avatar
Default will coilovers off an integra fit a civic
i have a 96 civic ex and a buddy of mine wants to sell me his coilovers off a 94 integra....i dont know if there the same or not let me know thanks
Old Sep 26, 2007 | 11:22 AM
BlueIntegraBoy's Avatar
Default Re: will coilovers off an integra fit a civic (ej8fasho)
It will fit
Old Sep 26, 2007 | 12:18 PM
koffeedc2's Avatar
the fronts will fit im pretty sure the rear is different. they changed the rear suspension on civic in 96 thats why you see struts for 92-95 and then different ones for 96-2000
Old Sep 26, 2007 | 12:30 PM
Default Re: (koffeedc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by koffeedc2 &raquo;</TD></TR><TR><TD CLASS="quote">the fronts will fit im pretty sure the rear is different. they changed the rear suspension on civic in 96 thats why you see struts for 92-95 and then different ones for 96-2000</TD></TR></TABLE>
The strut forks were different, but he's asking about coilovers and sleeves, which will fit.
Old Sep 26, 2007 | 01:48 PM
B16B_coupe's Avatar
HRD PKR
Default Re: (BlueIntegraBoy)
*if your using a sleeve coil over it will fit 92-00 civic 94-up teg..
*if your using full coilovers.. you will need to add washers in the back lower control arm bushing that holds the strut. or replace it with a eg bushing
*cause the 92-95 eg and 94-up teg has a wider rear bushing for struts.as the 96-00 is smaller..
* its about a 5mm washer needed for the rear
Ericezy
Suspension & Brakes
May 6, 2012 08:33 AM
pisetup
Nov 14, 2011 01:29 PM
grenthang
Nov 14, 2006 10:57 AM
User 42624
Suspension & Brakes
Sep 4, 2005 09:08 AM
EK VTi
Mar 17, 2004 04:42 PM
