PAINTING MY 4 DR INTEGRA
Old Sep 24, 2007 | 07:29 PM
kelviiv's Avatar
Default PAINTING MY 4 DR INTEGRA
I am painting my Acura Integra
I have 3 quarts of OMNI PPG Paint
And Enough clear coat, hardener, and reducer.
my MAIN question is how long should I wait for every coat for the paint, meaning how long of a flash time. and how long of a flash time for the clear coat after when finished applying the base paint and how long for every clear coat applied.
Please help
Will post pictures soon
Old Sep 24, 2007 | 07:56 PM
powerflow's Avatar
Default Re: PAINTING MY 4 DR INTEGRA (kelviiv)
Your best bet would be to have the paint supplier provide the data/tech info on the exact product, because it does vary. It depends on the room temp, reducer temp,hardener rate. I'm sure about 15 min. between coats will be in the safe zone, depending on the details of the product. PPG usually has reducer in the clear mix and 1:1 base, thats a lot of solvent, if your a noob, your better off to keep it on the safe side.
Old Sep 24, 2007 | 08:18 PM
kelviiv's Avatar
Old Sep 25, 2007 | 01:10 AM
ek4shizzle's Avatar
Default Re: (kelviiv)
hey good luck. i just painted my db.
im not sure about your stuff. but let the base totally dry. about 30-45 minutes between coats. you can clear the next day or after alittle bit, like an hour idk. clear shouldnt dry long. by the time you get around the whole car you can almost clear right away. let it dry until its tacky or you can slide your finger across or so. everything also depends on temperature and reducers/activators. also the brand of paint. ive never used omni.
btw what color and how much for those?
Old Sep 25, 2007 | 03:30 AM
powerflow's Avatar
Default Re: (ek4shizzle)
Did I confuse you some how? I was pretty clear. If you want an accurate answer your going to have to describe the individual products and your conditions. Base can flash off in little as a few minutes or much longer, it all depends.
crxsir23
Paint and Body
Feb 24, 2010 06:12 PM
skier4life0315
Honda Civic (2006 - 2015)
32
Mar 10, 2009 09:42 PM
drumminforev
Dec 8, 2006 10:10 AM
alupso
Sep 5, 2006 08:56 AM
dxhatch93
Sep 24, 2005 11:51 PM
