What should comp. test be for b16a head on b18c1 block? Thanks
Old Sep 24, 2007 | 06:23 PM
half jdm's Avatar
Default What should comp. test be for b16a head on b18c1 block? Thanks
Hi I am just about to do a compression on my motor and want to know what numbers to look for? I have a 94 b18c1 gsr block and 1st gen b16a head everything stock on the inside. Thanks for your help
Old Sep 24, 2007 | 07:42 PM
RCautoworks's Avatar
Default Re: What should comp. test be for b16a head on b18c1 block? Thanks (half jdm)
Should be around 220, but what really matters our all 4 numbers being close together.
Like 220,210,205,210
If you had 220,205,110,220
You would have a bad cylinder
Old Sep 25, 2007 | 08:17 AM
half jdm's Avatar
Default Re: What should comp. test be for b16a head on b18c1 block? Thanks (RCautoworks)
ok thanks for the reply I just did my test and I got 165-164-165-170 would this be good also would I expect to have lower compression than a stock gsr because I have a b16a head on a gsr block? Thanks
Old Sep 25, 2007 | 08:35 AM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks &raquo;</TD></TR><TR><TD CLASS="quote">Should be around 220, but what really matters our all 4 numbers being close together.</TD></TR></TABLE>
220? That seems high to me...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by half jdm &raquo;</TD></TR><TR><TD CLASS="quote">ok thanks for the reply I just did my test and I got 165-164-165-170 would this be good also would I expect to have lower compression than a stock gsr because I have a b16a head on a gsr block? Thanks</TD></TR></TABLE>
Yes, that's a perfectly healthy motor.
Old Sep 25, 2007 | 08:41 PM
NHswaps13203's Avatar
From: Swapin Motors,Tuckin Bays and Making Harness, CT, USfukenA
Default Re: What should comp. test be for b16a head on b18c1 block? Thanks (Tippyman)
the motors i test are usually around 245....u must be sure to hold the trottle wide open when doing the test
Old Sep 26, 2007 | 02:10 PM
Tippyman's Avatar
Default Re: What should comp. test be for b16a head on b18c1 block? Thanks (NHswaps13203)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NHswaps13203 &raquo;</TD></TR><TR><TD CLASS="quote">the motors i test are usually around 245....u must be sure to hold the trottle wide open when doing the test </TD></TR></TABLE>
And crank it the same number of times for each cylinder.
Old Sep 26, 2007 | 02:38 PM
STREETWERKZ's Avatar
You would have a bad cylinder</TD></TR></TABLE>
this is the correct answer......
also, different brand compression testers put out different numbers. you want them to be uniform or somewhat similar.
hidiouskinky
Oct 8, 2007 12:38 PM
douglas_be
Mar 12, 2004 12:36 PM
PUSHER
May 24, 2003 11:21 PM
