which injector size do i get??
Old Sep 24, 2007 | 05:39 PM
crazyjetsfan22's Avatar
Default which injector size do i get??
yea so im wondering which size injectors i should be getting for my set up. it is either between 310cc and 370cc. i also dont know wat brand i should get i hear RC are good and i have seen a lot of precision injectors for sale. i have seen stuff about needing clips for the injectors. am i going to need them.
here is my set up for my hatch.
Engine:
* 2001 GSR swap
* Skunk2 Pro Series Stage 2 Cams
* AEM Adjustable Cam Gears
* Port Flow Valve Springs and Retainers
* AEM Adjustable Fuel Pressure Regulator
* B&M Fuel Pressure Gauge
* Password: JDM Carbon Fiber PowerChamber Intake
* Skunk2 Pro Series Intake Manifold
* JDM Integra Type R 4-1 Header
* Stock GSR P72 ECU ( will be getting this chiped when i get it tuned!!)
Exhaust:
* Apexi World Sport 2 60mm Piping (2.36")
* Omni Power Test Pipe
im also getting a Walbro 255 lph High Pressure Fuel Pump.
Modified by crazyjetsfan22 at 9:54 PM 9/24/2007
Modified by crazyjetsfan22 at 8:07 PM 9/27/2007
Old Sep 24, 2007 | 05:48 PM
JDM JEFFREY's Avatar
310 will be fine
Old Sep 24, 2007 | 05:54 PM
Default Re: (JDM JEFFREY)
yea thats wat the tuner said i emailed him! am i going to need the injector clips??
Old Sep 24, 2007 | 06:46 PM
Default Re: (crazyjetsfan22)
bump i need to know soon im looking to order them in the next day or so
Old Sep 24, 2007 | 07:19 PM
bsballboyjk's Avatar
http://www.rceng.com/technical.aspx
its a little confusing but if you take the time to figure it out it may help guide you
Old Sep 25, 2007 | 07:46 AM
pomansouth01's Avatar
Ginger Kid
what is wrong with the stockers....they are good to about 205 whp...
Old Sep 25, 2007 | 07:54 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: (pomansouth01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pomansouth01 &raquo;</TD></TR><TR><TD CLASS="quote">what is wrong with the stockers....they are good to about 205 whp...</TD></TR></TABLE>
X2 agreed. There's nothing in this set-up that says you'll get close to 190 whp.
You do better by getting a 3.0" intake and selling or getting rid off the password chamber thing. The intake can be sized to give the best performance.
Modified by mar778c at 9:48 AM 9/25/2007
Old Sep 25, 2007 | 03:45 PM
2.0 and up's Avatar
Default Re: which injector size do i get?? (crazyjetsfan22)
310cc will be good especially with a fpr...
Old Sep 25, 2007 | 04:19 PM
kpowerdhatch's Avatar
Ditch the pro 2's, they are too big and get a better header.
Old Sep 27, 2007 | 04:01 PM
Default Re: (kpowerdhatch)
ne one else got imput??? i wanna no soon i gotta get a date for the tuner!!
Old Oct 9, 2007 | 11:55 AM
Ginger Kid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyjetsfan22 &raquo;</TD></TR><TR><TD CLASS="quote">ne one else got imput??? i wanna no soon i gotta get a date for the tuner!!</TD></TR></TABLE>The stock injectors are more than enough for your setup. Get smaller cams....better matched up products will yield a faster car....more midrange torque and a braoder power band....
Old Oct 9, 2007 | 12:12 PM
b20beast978's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kpowerdhatch &raquo;</TD></TR><TR><TD CLASS="quote">Ditch the pro 2's, they are too big and get a better header.</TD></TR></TABLE>
x2!! if those are the pro series cams throw them away, they will be useless...they are way too big and you will be overcammed on a 1.8 unless you have a ported head, free flowing exhaust and a adequate intake system
Old Oct 9, 2007 | 12:34 PM
Ginger Kid
Default Re: (b20beast978)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20beast978 &raquo;</TD></TR><TR><TD CLASS="quote">x2!! if those are the pro series cams throw them away, they will be useless...they are way too big and you will be overcammed on a 1.8 unless you have a ported head, free flowing exhaust and a adequate intake system</TD></TR></TABLE>
I had a ls/vtec that made good numbers with a stock head....had a very broad torque curve....compression is VERY important for these cams. If you have a stock head, that is fine....I suggest 12.5 to 1 static compression atleast though
Old Oct 9, 2007 | 01:24 PM
I had a ls/vtec that made good numbers with a stock head....had a very broad torque curve....compression is VERY important for these cams. If you have a stock head, that is fine....I suggest 12.5 to 1 static compression atleast though</TD></TR></TABLE>
hold on a sec lets get this straight...are these STAGE 2 Or PRO 2 skunk cams we talking about?
lilo_goki
Jul 2, 2009 02:11 PM
KartelB
Jun 4, 2009 09:41 PM
jcvelez360
Oct 31, 2007 08:22 PM
mitcheg6
26
May 18, 2007 09:19 AM
Th3savinday
Mar 3, 2007 11:45 AM
