headlight bulbs for 94 accord lx
Old Jun 18, 2002 | 05:13 AM
PearlWhiteAccord's Avatar
Default headlight bulbs for 94 accord lx
Hi,
what size and where do u get them at what price???hyper whites?
Old Jun 18, 2002 | 05:15 AM
Gennady's Avatar
New User
Default Re: headlight bulbs for 94 accord lx (PEARLWHITEACCORD)
9006 for regular (outside), 9005 for high-beams (inside). Where do you live? I can help you out about where to get them and at a good price.
Old Jun 18, 2002 | 05:16 AM
SOHCArchangel's Avatar
you want rice lights?
anyways, the drivers bulb is 9004/9006? cant remember
normal bulbs can be found at any trak/pep boieez
rice lights, are found at your local rice distributor, open up a rice mag like scc or stupid street y0!
Old Jun 18, 2002 | 05:17 AM
Gennady's Avatar
New User
Default Re: headlight bulbs for 94 accord lx (SOHCArchangel)
Old Jun 18, 2002 | 05:23 AM
YeuEmMaiMai's Avatar
since I do not use my high beams I only installed the 9006 for the inside (low beams) they are blue and are much easier to see with at night.
Old Jun 18, 2002 | 05:28 AM
Default Re: headlight bulbs for 94 accord lx (YeuEmMaiMai)
well all the rice lights are of a higher wattage, given their short life and 'easier sight' anyway i use 100w h3's in my projectors, a regular plain ol bulb, and it lights up everything color/brightness/lumen output/and intensity are not the same the colored bulbs put out less useable light as the wavelength generated is higher in the spectrum and there is less density of that wavelength that is why they rice bulbs have to run at a higher wattage
Old Jun 18, 2002 | 05:38 AM
they are only 55W each......They have a bluish tint because the glass is colored blue. My car is not rice at all it is stock looking and just has fog and blue lights
Old Jun 18, 2002 | 08:43 AM
CD8's Avatar
CD8
hyperwhites, superwhites, hyperblues, superblues, hypersuperblues, superhyperwhites =
Old Jun 18, 2002 | 09:22 AM
KTeller8's Avatar
Default Re: headlight bulbs for 94 accord lx (exaccord)
how do you fit 9006 in where the 9005's are,, if you cut the wires and rewired the low beams with the high beam clamps will this overheat and melt the wires?
you said you run your high beam lightbulbs in the low beam section correct? or do you just swap them inside the engine bay?
Old Jun 18, 2002 | 12:21 PM
Kazmans94cord's Avatar
misa, i thoguht you had Raybrigs?
Awsom-o 4000
Jun 21, 2009 08:52 PM
phoenix_iii
Aug 8, 2008 11:54 AM
nickoz21
Mar 14, 2007 01:37 PM
stock97
Jul 25, 2003 06:54 PM
