Best Sub/Amp combo for the money? Should I run 2 or 1?
Old Sep 24, 2007 | 03:38 PM
m1ndless's Avatar
* B A N N E D *
Default Best Sub/Amp combo for the money? Should I run 2 or 1?
I currently have 1 MTH Thunder 5500, hooked up with a cheapo walmart amp, it bumps, but I want better SQ. .
I have about $400-$500 to spend if needed.. but obviously the cheaper the better..
Here are my options I am considering..
Buy another MTX Thunder 5500 and push 2 10"s, and use a cheaper amp
or
Just use my current sub, and invest in a really nice amp
or
sell my sub to my friend, and use new subs and amp but for under 400-500?
I want really deep bass, I don't care how loud the bass is, I just want really good quality bass. Qulity over Quantity!
What would you guys suggest?
Old Sep 25, 2007 | 07:26 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Best Sub/Amp combo for the money? Should I run 2 or 1? (m1ndless)
Toss that cheap amp and buy a mtx amp or a quality amp. And build a enclosure to match that sub and you will have some deep bass and sq at the same time. Thats a nice sub.
Old Sep 25, 2007 | 03:13 PM
m1ndless's Avatar
* B A N N E D *
Default Re: Best Sub/Amp combo for the money? Should I run 2 or 1? (wrx-killer-Sti-eater)
I found an infinity 611a amp for $150 shipped on SD, I may jump on that.
In a small truck, like an s10 or ranger, would a ported or sealed enclosure soung best? I like the deep thump more than the rattle..
Old Sep 26, 2007 | 01:38 PM
skingfreak's Avatar
it kind of depends on the amount of space your willing to give up since sealed is smaller than vented.
Old Sep 26, 2007 | 05:33 PM
fcm's Avatar
fcm
Old Fart
I have to agree, the MTX Thunder 5500 series is a pretty good sub, [I assume it's a T5510-04 or -44] a 300W continuous power handling sub.
Stick with a sealed box, clean, tight and accurate sub bass.
The Infinity REF661A is a 1x456W RMS into 4 ohms and 1x657W into 2 ohms, so as long as your sub is the -04 then it will work for one or two of them. 94
m1ndless's Avatar
* B A N N E D *
Default Re: Best Sub/Amp combo for the money? Should I run 2 or 1? (skingfreak)
Space isnt a problem, its going to be in an ext cab s10, lots of room behind the seats.
deeweezy187
Audio / Security / Video
Jul 6, 2006 09:07 AM
Znypar
10
Mar 14, 2006 08:06 AM
JamesQ
Dec 21, 2003 11:48 AM
BlackAC99
Dec 12, 2002 06:27 PM
ShowSpeed
10
Dec 10, 2001 09:20 AM
