D16z6 problems
just put fresh d16z6 in y 92 hatch. the car boggs when going full throttle. sounds like a WRX. what could cause this? also my battery won't hold a charge and dies after running for a while. battery is good and alternator is good( both were tested). i have check everything and can't seem to find out whats the problem. i need some possible solutions. thanks
My CX has a D15B7 Head on it right now with a Compression leak and Gurgles like a WRX and has no power untill it breaks 4500RPM where the pistons are spinning fast enough to hold Compression, Check your compression, and do a Leak-down test.
Also if your alternator and battery are good Check your Grounds, and Check that the belt is tight.
ok sounds good. how many grounds should i have and where would they be located? and yes i am throwing a code but i can't check it because my jumper harness was cut by previous owner. i have no idea why.
You'll need to find a way to read those codes. and a missfire will cause your car to run like that. But a good start would be to find out what codes you have, that could get you headed in the right direction.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolD16 »</TD></TR><TR><TD CLASS="quote">ok sounds good. how many grounds should i have and where would they be located? and yes i am throwing a code but i can't check it because my jumper harness was cut by previous owner. i have no idea why.</TD></TR></TABLE>
1.) the grounds are - transmission to frame rail on the passenger side, thermostat to ring-terminal on the wiring harness just below the throttle body and valve cover/power steering bracket to core support.
2.) the cut wires for the harness merely need to be touched together to have the code blink on your gauge cluster. If you can't make that happen, we can't help you.
ok i found out alot of problems. my alternator went bad even thought it tested good at adveance. need a new battery. redid all my grounds. changed all spark plugs and distributor( lots of money..haha) cars runs great but still kind of boggs a little so i will be doing a compression test soon and will find out what codes im throwing. thanks for the help
mosagalzeta
Jul 20, 2015 02:31 PM
jsoccer
Aug 18, 2010 01:18 PM
accrdwgnguy
17
Jan 6, 2009 03:24 PM
SpoolD16
Sep 12, 2007 01:34 PM
