taking my head off
I believe there is, if you have a chilton/haynes/FSM it will be in there. Don't quote me on this but if I recall, without looking for a pattern, it's inside/middle bolts first then work your way outward in a crisscross pattern. Reason is to avoid warping the head. I can check later when I get home if you like.
BUMP FOR SALINAS
BUMP FOR SALINAS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 24TEN »</TD></TR><TR><TD CLASS="quote">I believe there is, if you have a chilton/haynes/FSM it will be in there. Don't quote me on this but if I recall, without looking for a pattern, it's inside/middle bolts first then work your way outward in a crisscross pattern. Reason is to avoid warping the head. I can check later when I get home if you like.
BUMP FOR SALINAS
As I recall its outside in on removal inside out when installing, so in other words start with the outer most bolts and then work your way in. It's not as important on disassembly as it is on reassembly
BUMP FOR SALINAS
</TD></TR></TABLE>As I recall its outside in on removal inside out when installing, so in other words start with the outer most bolts and then work your way in. It's not as important on disassembly as it is on reassembly
dcamper24
Dec 16, 2007 11:44 AM
rollydc69
Dec 2, 2005 06:25 PM
