Suspension Techniques kit work with a ITR rear sway?
will the kit hold up the ITR rear sway bar the same way as the ST would hold their rear sway bar? im referring to the kit that has the endlink adapter with the L bracket that links to the bolt that holds the rear forks
Im sure if you were absolutely set on such a route it would be possible, but I wouldnt do it. Thats would put both ends of the endlink at a pretty sever angle, both for the balljoint or helm joint end on the swaybar, and for the pogo style endlink attachment on the lca.
Its not something I would consider at all safe.
That would also incurr a higher motion ratio, increasing the stiffness of the bar by some amount you would have to figure out.
turbotime
Dec 26, 2004 11:39 AM
