96 civic making nocking noiseby valve cover any ideas
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondahannah »</TD></TR><TR><TD CLASS="quote">my screen up top says honda civic/del sol 1992-2000
Because it was moved, oh smart one.
on you.
</TD></TR></TABLE>Because it was moved, oh smart one.
on you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nivekrdz »</TD></TR><TR><TD CLASS="quote">took valve cover off sounds still there all vavles are movingany ideas what it couls be</TD></TR></TABLE>
how are you not squirting oil everywhere with the valve cover off and the engine on?
Make sure that what you're not hearing is knocking from the block, first off.
I would check the valve clearances, then check the timing. Those would probably be the 2 easiest things you could do. Remove the spark plugs and check the color of them. Make sure the engine electrical is working well ( dizzy, plugs, etc ) .
ShinotakuX
11
Jun 26, 2007 09:52 PM
