ZC ecu help....
Old Jun 18, 2002 | 12:34 AM
ICC96INTEGRA's Avatar
Default ZC ecu help....
I have a ZC engine and tranny, but I need the ECU and Harness. Is there another ecu and harness I can substitute it with. Thanks for the help...
Old Jun 18, 2002 | 04:15 AM
therealciviczc's Avatar
Default Re: ZC ecu help.... (ICC96INTEGRA)
Most people just use the Si harness and the 88-89 Integra ECU.
For the Si harness, you'll have to repin the plug that goes to the distributor from a 7 pin round plug to separate 5pin (distributor) and 2 pin (cam sensor) plugs.
Old Jun 18, 2002 | 07:27 AM
HF2ZC's Avatar
If you also need the distributor and cam angle sensor plugs, you can get them off of an 88 - 89 Integra. Oh yeah, and the ECU from an 88 - 89 Integra 5spd will work, but you will need an ecu case from an 88 - 91 Civic / CRX to bolt it to the floor.
JScott3d
10
May 9, 2010 08:25 PM
ludecrasy87
Nov 29, 2006 12:24 PM
CrX_RiDInG
Jul 26, 2006 02:25 PM
saucycivic
Jun 16, 2001 05:13 AM
